Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Vectra 1.8LS 955 power steering fault?? or not
    May 2008
    antrim
    StatsVehicle Info
    Angry Vectra 1.8LS 955 power steering fault?? or not
    First of all hello to everyone here good job on the site! Now, where do I start.... I own a Vectra C 1.8LS 2002, problem free motoring until last sunday, tried to start the car after a quick stop on a short trip and the engine management light came on and a horrible lumpy sound as the engine tried to start but wouldn't. Got the car taken to a garage and they reckoned after 2 hours of diagnostics and 197 that I needed a new poweer steering pump, now the bill goes up to 955. Picked up the car on the 7th, drove 20 miles tried to start it again and whammo, same problem I just paid best part of a grand having repaired is back. Garage say they fixed the problem and now want to charge more for further diagnostics and different parts if the power steering pump is not the problem. Obviously I am a little bit upset about this and wonder what advice you lot could give me on the possible fault and what to do about the garage?? Thanks in advance for any replies or advice!! Sorry i posted this in the wrong place first!
    StatsVehicle Info
    the power steering pump won't in anyway effect the engine.. it's an electric pump, not driven off the engine..and horrid lumpy sound from the engine will not be related to the pump at all....What you need is a full TECH2 diagnosis on the car to see what is REALLY the problem.. it will be the best £40 you could ever spend
    May 2008
    antrim
    StatsVehicle Info
    Thanks gsi 3, so how do I go about getting a TECH2 diagnosis? You reckon the vauxhall garage is pulling a fast one about the pump, in no way would it affect the engine management?
    StatsVehicle Info
    the engine management and the pump are run by two different computers...take it to another VX dealers and report back with the tech2 codes.....
    May 2008
    antrim
    StatsVehicle Info
    cheers again, can't get the codes till monday now, they have already done diagnosis for 2 hours with the computer, is that the TECH2 diagnosis? It is a vauxhall dealership I used! 197 for 2 hours worth, ripped off there as well? Not happy at all
    Regular Member benny's Avatar
    Feb 2006
    dudley
    StatsVehicle Info
    the power steering pumps on vec c play a role in the engine man system if the pump has a can bus failure they will put out the wrong can bus mesages and this can stop the car from starting .if this has hapened this may have been your original fult and now you have a different failure i would ask for the original codes and there checking procedure that led them to think it was the pump... i would think your fault lies with the abs plug or the cim ...but this will need to be checked ....if they cant suply the codes or the diag procedure then you can get them to look at it again for free i would think..but one thing i will add with the older vec c's it can be a little hard to find the faults due to the complex nature of the systems i myself have been led up the garden path many a time looking for faults on these cars.....hope this helps benny
    May 2008
    antrim
    StatsVehicle Info
    From a customer service point of view, what do you think they should do about the money I have already paid which didn't fix the problem?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    StatsVehicle Info
    as its a electrical item it wont be able to be returned so you should ony pay for the item and not any labour money imo
    May 2008
    antrim
    StatsVehicle Info
    Having done some more research on other sites it sounds to me like the camshaft sensor, rough idling then cutting out with engine management light illuminating. Anyone think this may be more along the right lines or had any experience of this?
    StatsVehicle Info
    1 of the 3 popular 1.8 faults, yes..
    they have an 'appetite' for camshaft sensors, crankshaft sensors and idle valves..
    the only way to ever find out 100% is to get it plugged in somewhere else other than that first garage
  1. Power steering fault
    By Mattle40 in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2013, 13:50
  2. Power steering fault
    By gazspeight in forum Engine & Drivetrain
    Last Post: 15th September 2011, 20:41
  3. Power steering fault ?
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2010, 20:20
  4. power steering fault?
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 21:39
