Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Vectra-c newbie with serious problems!!!Advice needed
    May 2008
    antrim
    Angry Vectra-c newbie with serious problems!!!Advice needed
    First of all hello to everyone here good job on the site! Now, where do I start.... I own a Vectra C 1.8LS 2002, problem free motoring until last sunday, tried to start the car after a quick stop on a short trip and the engine management light came on and a horrible lumpy sound as the engine tried to start but wouldn't. Got the car taken to a garage and they reckoned after 2 hours of diagnostics and £197 that I needed a new poweer steering pump, now the bill goes up to £955. Picked up the car on the 7th, drove 20 miles tried to start it again and whammo, same problem I just paid best part of a grand having repaired is back. Garage say they fixed the problem and now want to charge more for further diagnostics and different parts if the power steering pump is not the problem. Obviously I am a little bit upset about this and wonder what advice you lot could give me on the possible fault and what to do about the garage?? Thanks in advance for any replies or advice!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Seems to be the normal way with garages these days - garages keep replacing parts which you pay for until, with luck, they manage to fix the problem.
    A friend had the EM light on his Merc come on - The Merc garage replaced the Air Flow Meter & reset the light - which came back on a couple of days later. The garage told him the fault was diagnosed as 1 of 2 things so now they would have to replace the other part but couldn't do anything about the £850 which he had already spent
    as per your other post..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    What would the power steering pump need to repalced for if the car would not start. very confused??? New one is £600 and takes about 30 mins to fit and then may have to be tech 2'd in as your old one would have an oil level indicator. The new one will not have. i suggest u check to see if a new one is fitted. Its under the front drivers wing/bumper. I have had a power steering pump go and all it does is make the steering heavy. think u have been done mate!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by merikiito View Post
    yes you right about the steering being very heavy as last year i was driving for 3 months without power steering and i didn't get mine tech 2. some have fluid levels and some dont as for the garage wrongly diagnosed i would tell them to but the old one back on and refund the money as for cutting out it might neeed tech2ed to see if there is any faults on the ecu
    May 2008
    antrim
    Thinking exactly the same, ripped off, I had a look at the diagnostics sheet and it did say the problem was the EHPS, electric hydraulic power steering they reckoned, got to be honest, not to knowledgeable about cars, as the garage probably are all to aware of!
    May 2008
    antrim
    Asked the garage to replace the part with the old one and they said that it was the sensor in the old one due to water ingress and with the old one fitted the diagnosis wouldn't go any further than that component!
    Quote Originally Posted by slyneely View Post
    i cant see how water can get in as it has a tight sealed fluid cap and two pipe that feeds the steering rack withn minerale steering fluid and on the side is 2-3 connector block 1 big block which is for the earth and live feed a cable from pump to rack and the 3rd one is for fluid level if you have it. so as mark said in the other post it WILL not affect any running problems with the engine
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    When my pump went the dash died and the car would not start after I turned it off. Car then started 15 mins later.
    Belfast
    If it's Townparks that ripped you off, tell Rodney to wise up.
  1. I'm going to have to part with my Vectra (advice needed)
    By Karnah in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 11:43
  2. Vectra c Est modification advice needed!
    By giles in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 17:09
  3. vectra c 2.2 advice needed
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2009, 19:52
  4. Newbie Advice needed please 2.2 Direct with a strange rattle...
    By simp_2.2sri in forum Introduce yourself.
    Last Post: 10th August 2008, 17:24
  5. Newbie, Buying a Vectra C advice...
    By C9SRi in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 13:15
