Results 1 to 10 of 11
Thread: DAB box error
    Regular Member carlton's Avatar
    Oct 2006
    Planet Earth
    Default DAB box error
    Hi all, my DAB has packed up, getting the above message. Anyone had it? or know how to reset the unit?
    It still under Net Q warranty and i hope the stereo is covered!
    Its a CDC40 Opera
    Regards
    Carlton
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    The radio should still be covered by the warranty.
    The DAB box lives in the footwell from memory (search DennisTheMenace threads for pics of the location) and check if there's a loose cable somewhere, or possibly a blown fuse (maybe onboard and not in a fusebox) - I can't remember if its powered from the CDC40 or separately.
    Feb 2006
    Dorset
    DAB box is in the far left hand corner by the bulkhead its at the end of the rail with the relays in , its held by 2 10mm nuts , you should find switching the car off for 30 mins will cure it , mine was loosing stations a few weeks ago but has cured its self !
    Oct 2006
    Planet Earth
    Its cured, didnt lose any stations, but it was after trying a new aerial. I have put the original aerial on again and its back up and running, so i will leave it in place.
    Thanks for the advice
    Regards
    Carlton
    May 2008
    Dunfermline, Fife
    Mine did the DAB Box error thing on Sunday. I switched the car off and left it for an hour or so and it cured it.
    Regular Member Woodyuk's Avatar
    Essex
    Engine : 2.0 DTi
    I wish I had DAB to worry about
    Feb 2016
    Sheffield
    Trim : Vxr 280
    Engine : 2798
    Default Cdc40 dab error no fm/am
    [QUOTE=Woodyuk;585707]I wish I had DAB to
    Last edited by Cadetski1984; 28th February 2016 at 09:42. Reason: Wrong place posted
    Feb 2016
    Sheffield
    Trim : Vxr 280
    Engine : 2798
    I have a cdc40 in my Vectra Vxr 08 it says error and stopped on Monday 15th like lots others is this a coincidence I can't get fm/am just static noise in background any ideas aerial maybe?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    8 year old thread wow,
    Regular Member ajcollins2's Avatar
    Jul 2014
    Ashford Middlesex
    8 Post(s)
    Vehicle : Vectra VXR & Vectra C 1.9 SRi
    Trim : VXR & SRi
    Engine : Z28NET & Y19DTH
    Mileage : 53000 & 1
    See here, loads of us with it, all happened between 7th and 9th of feb
    https://www.vectra-c.com/forum/showt...40-Opera/page6
  1. cd error
    By vicfzy in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 14:55
  2. DAB box error
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 21:30
  3. which error?
    By steve1412 in forum Engine & Drivetrain
    Last Post: 9th February 2011, 20:00
  4. Help!! Error CD?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 18:36
vauxhall vectra dab box error
dab box error
cdc40 opera dab box error
dab box error vauxhall vectra
https:www.vectra-c.comforumshowthread.php47967-DAB-box-error
vectra c dab box errordab box error vauxhalltroubleshooting dab radio errors in cdc40 operadab box error cdc 40dab box error vectra cdab box error vauxhall astravauxhall dab box errorfaulty dab radio vauxhall vectra designvectra 06 dab box error jak naprawicvauxhall zafira dab box errordab box error vectracar radio dab box errorcdc 40 opera DAB box errorvauxhall vectra dab boxvectra DAB boxcdc 40 dab box errorvectra dab radiowheres the dab box go on a corsa vxr for the cdc opera how to fix a dab box error on.a vectra
