Thread: Slight grinding through Steering wheel.?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default Slight grinding through Steering wheel.?
    hi ya Peeps...
    Wonder if you could shed any light light on this little issue..?
    I have an 57 5k veccy Sri estate 1.9 CDTI..
    When you drive around you can feel thorugh the steering some slight,feels like grinding or tiny vibrations, its only 8months old, often in a straight line on a smooth road it all but disappears, but if you begin to turn the wheel, it comne backs and fades out, turning either way.. any ideas?
    Tyres are correctly inflated, and tyres are in good shape, no uneven wearing. brake discs are nice and clean, no score's, albeit the inner disc is slighly more worn than the outer disc on both front discs. having only had this motor for a month or so, its always done it from stealer. just that on my works van and other car (both diesel) neither do ot at all.
    And advise... ??? do i sense a trip to VX...?
    or am i goning...
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    As it's the inner side of both discs, would this thread help? http://forum.vectra-c.com/showthread.php?t=47880
    On the photo, it's the bit outlined in red. And to anyone who notices, yes, the car is supported on the scissor jack but I wasn't under the car
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    what is it..? did this cause your problem? as its only very slight, more so on cornering? anything to worry about?
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    bump... thx
    that is the lower balljoint dust sheild.. if it's rubbing the disc then it'll make the noise..always worth a check it's clearly off the disc.
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Quote Originally Posted by gtr1000 View Post
    Just what iv been looking for, cheers!
    Regular Member EliteSingh's Avatar
    Around ;)
    Fwohhh, boy am i glad i cam across this thread.
    1. I thought my brake pads had worn and needed replacing even tho the ones facing outwards hav a thickness on em.
    And
    2. I'd just now broken the crappy Vx key for the locking nut, how ghey is that eh!
    thank phook for this site!
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Peeps, sorry to re-incarnate this..
    after many months with the grinding through the steering it went in VX today!, the best way to explain it it that your holding onto a grinder (running) its that type of feedback through the steering. Very annoying on long runs. Not to mention the road noise, i know its an estate... but wow! got to be the loudest car ever driven.
    Anyways.. VX say its a loose AC pipe...??? i think they are blagging me and also the second fault it went in for was difficulty in selecting 2nd gear only when cold.. VX advise No fault found... It appears that anyone other than VX can have the issue!
    As the warranty draws to a close, i thought i better get these done.
    So has anyone else had a similar issues?
    thanks in advance
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I had a slight grind through steering wheel and it turned out to be top strut bearings
    Irmscher Insignia CDTI 130
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Quote Originally Posted by bigmac View Post
    Is this something that a VX tech could diagnose?
  1. Replies: 7
    Last Post: 5th May 2011, 12:29
  2. Replies: 6
    Last Post: 13th March 2011, 10:47
  3. Grinding on steering left and right
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2011, 00:15
  4. Strange grinding noise coming from rear wheel
    By sproket in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 22:04
  5. Slight steering wobble on 19" snowflakes
    By paulo in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2007, 23:53
astra estate 1.9 cdti vibration from steering wheel
