Results 1 to 10 of 17
Thread: Centre heat shield lugs
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Default Centre heat shield lugs
    I've had an irritating rattle from the car last couple of weeks, and finally found it today. The centre heat shield on above the exhaust has dropped on the offside so it's flapping about.
    It looks like the holes (arrow) have corroded and dropped past the nuts that hold it. Ideally I'd like to just undo the nuts (marked in the photo) and use one or two larger washers to secure it back in place - provided the nuts will undo.
    Question is does anyone know if the studs in question hold anything else? They look to be "blind" from what I can see into part of the underside bodywork, but I'd like to be sure before trying to undo them and find I can't do the damned things back up.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    when you say rattle mate is it like a vibration noise when you pull off in low revs? and it makes a metal sounding rattle
    Feb 2007
    North Somerset
    Quote Originally Posted by vectragsi3.2 View Post
    No - I'm pretty sure this is the cause of the noise. It's mostly over bumps and at motorway speeds, where I think the airflow is flapping the shield around.
    Feb 2007
    i only ask mate as i have that rattle and thought it maybe the answer to my problem!!! its so annoying! im sure the nuts will undo and the shiels will fasten up with washers but someone should be along to tell you more
    Feb 2007
    North Somerset
    Ah I see. Noises like that are a nightmare to find. I was convinced this was inside the cabin, it's only because I was checking the back boxes, wheels and tyres I noticed this was hanging loose.
    Dead easy to check though from the side of the car, where its dropped it can be lifted with one finger.
    Feb 2007
    North Somerset
    Well, I shouldn't have worried about undoing them - blasted things sheared straight off .
    I guess it will be self tapping screws but I'll need to get it on ramps as my drill won't fit under and I'm not happy just using the jack in this situation.
    I've managed to use 3 metal clips on the edge of the plate into what I guess are drain holes, but whether they'll stay in place once I get back on the motorway I doubt!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you will need to undo the old nut carefully so the dont snap an use a bigger washer then refit the nut job done
    Feb 2007
    North Somerset
    Quote Originally Posted by glynn View Post
    Soddin' things were corroded so badly they might as well have been welded on - no chance of getting them off in one piece. I'll have to drill through and secure them with new bolts in another place near the drain holes but only when I can safely get under the car.
    Regular Member stevedee's Avatar
    keighley
    Thumbs up
    that looks just like my heatsheild lol our cars might be twins , might take it off comletely and replace with a new one or leave it off completely
    will have a look and see what the best way is
    cheers
    steve
    Feb 2007
    North Somerset
    I wouldn't take it off completely without a replacement - you may heat up bits above it not intended to heat up .
    I used some map clips (of all things!) as a temp solution until I can get under to sort it properly.
  1. heat shield
    By beat275 in forum Bodywork & Interior
    Last Post: 16th February 2013, 15:02
  2. heat shield
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th May 2012, 02:11
  3. Heat shield.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2009, 22:37
  4. Heat Shield
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2008, 22:12
fitting heatshield clips vectra
