Results 1 to 10 of 20
Thread: Auto locking.
    Regular Member detritus's Avatar
    Jan 2008
    West Midlands
    Default Auto locking.
    Folks, I have just enabled the auto locking feature on the SRi; when the car sets off, all doors lock as normal but when I stop and turn off the engine, only the driver's door unlocks. This means that when ever the missus wants to get out i have to use the manual central locking button. Is this just the way I did it or does every car with auto locking enabled so this?
    Detritus.
    Regular Member cbee101's Avatar
    Apr 2008
    Blackpool
    mine opens all the doors when I take the key out.
    2 beeps on setup if I remember rightly.
    54 plate SRi
    Regular Member kpf1grandprix's Avatar
    luton beds
    mine does the same ,jusr the drivers door
    Regular Member Joeblack's Avatar
    Doncaster
    mine used to open all my doors - that was on my pre-facelift sri, now on my facelift it only opens drivers side too, maybe its another cool feature they have taken off the facelift !
    Aug 2007
    Leicester
    When you open the car, does one press of the key fob open only the drivers door?? or all the doors.
    My facelift, all doors lock on drive off, all doors open when key removed. Key fob opens all doors when pressed.
    I'm pretty sure it is all settable - just adjust in line with what it says in the manual.
    luton beds
    Quote Originally Posted by Jaffatubes View Post
    yeh 1 push of the fob opens drivers door lock,,2 opens all
    Chester
    All the doors open on my 57 plate Sri and did the same on my 06 Exclusiv. It's just the way you choose to set it up.
    Swindon
    you will need to change the setting on how the car unlocks from the key.
    If you press the button once and all doors open, then when you turn your engine off all the doors will unlock.
    If you have to press the unlock button twice to unlock all the doors on your car then this will be repeated on the opening of the auto lock function. i thinks it's one or the other people.
    As i have kids i just chose to have all doors open when i unlock the car as it's easier, also works great with the autolock function.
    wolverhampton
    do the signums have this? and if so how do you get it activated
    Jan 2008
    West Midlands
    Ah, I think I understand. So if i set the key to unlock all doors on the first press then the auto (un)lock will open all doors when I turn the engine off.
    Super, thanks guys, im off for a play.
    Detritus.
    edit: steve-wolves, First look in the key/locking section of your owner's manual, it describes how to turn off the one press = drivers, two press = all doors unlocking feature of your key. if the one press = drivers feature is on then only the drivers door will auto unlock when you turn off the engine. If the one press = all doors is enabled then all doors will auto open when you turn off the engine.
    You sit in the car with the key in your hand. at the same time press and hold the door lock button on BOTH the key and the drivers door (next to the window/mirror control). After a few seconds you will hear a double beep from the car. The feature os now set up and the car will auto lock when you pull away and reach about 8(ish) mph. The car will unlock when you turn off the engine. Its in the key/locking section of your owner's manual.
  1. auto locking?
    By advect in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2010, 11:02
  2. auto locking
    By iansfocus in forum Bodywork & Interior
    Last Post: 5th January 2010, 11:49
  3. Auto Locking!
    By H11LGX in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 23:54
  4. Auto locking.....
    By ROY2593 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2007, 17:58
  5. auto locking
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2005, 12:43
