Thread: 235 35 19 what psi ?
    Regular Member STAV's Avatar
    Oct 2006
    tyne & wear hebburn
    Default 235 35 19 what psi ?
    got some 235 35 19 wrapped arround my wheels what pressure would the fronts and backs be?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by STAV View Post
    you will need about 36-38 psi m8
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    for the GSi front 44 rear 39.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    5 Post(s)
    Trim : GSi
    Mileage : 190,000
    I know it's probably been asked a hundred times but what are the tyre pressures meant to be for a GSi on 17" wheels and tyres? I run mine on 38 psi all round and it seems fine to me but I wouldn't mind knowing.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Quote Originally Posted by GSiFan View Post
    Paul
    I've got the 3.2 Elite on standard 17" wheels and 215/50 tyres - these are 40 front and back in the handbook (same in the handbook for 225/45 as well)
    5 Post(s)
    Trim : GSi
    Mileage : 190,000
    Cheers! I shall give 40 psi a try, then. Mine are 225/45/R17s but it should still be fine, I'd have thought.
    Paul
    Regular Member rosssri's Avatar
    S.Lanarkshire
    My Toyo 235/35/19's state on the sidewalls that psi should not exceed 40 psi! I've got the fronts sitting at 38 and the rears at 35.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    81 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by rosssri View Post
    In that case i hope no one has toyo's fitted to either a VXR, 3.0 cdti or a fully loaded Veccy as they all have tyre pressures above 40psi if loaded
    as taken from page 306 of the handbook, (dated Jan 07)
    front rear front rear
    saloon / hatch / estate fitted with 235/35/19
    .................Normal.....loaded
    VXR & 3.0cdti 42 38 / 45 51
    1.9cdti & 2.0dti 39 35 / 41 48
    1.8 & 2.2 39 35 / 41 48
    Might be worth a checking...
    Oct 2006
    tyne & wear hebburn
    so does the psi stay the same no matter if you are on 17" 18" or 19" then ?
2353519 psi
