Thread: Metallic High Pitch Squealing Noise
    Lincoln
    Default Metallic High Pitch Squealing Noise
    Hi all. I have noticed in the last few days a really high pitch squealing noise coming from the front of the car !
    It only occurs when I turn the steering wheel to the left, or take a left hand bend. It does not do it the other way round - i.e turn the wheel right or turn right
    It sounds like its coming from the drivers side front wheel.
    I first thought it could be the brakes, so I took the wheels off to take a look & everything seems fine. It's a really deep penetrating metalic sort of squeal.
    Any thoughts would be greatly appreciated before it has to go in to be looked at
    Feb 2007
    Glasgow
    There's a little heat shield near the bottom ball joint on the steering knuckle that has a habit of rubbing on the disc. If that's what it is, just bend it out of the way.
    Lincoln
    Thanks Shunter I'll take a peep when I get in from work and let you know the outcome.
    sounds a firm favorite..... bend it right back out of the way.....
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    must be catching ....excuse the pun this problem
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Strangely enough today, I thought I'd got a knackered o/s wheel bearing.
    Having removed the brake caliper, the squealing noise was still there so it wasn't the brakes.
    After nosing round underneath, there it was - the flimsy metal whatever you call it was rubbing on the disc.
    Pulled it back, job done.
    However, forgot to grease the coil suspension cups as in this hot weather, the suspension is back to making those boing boing noises.
    EDIT - was the n/s, not the o/s, same as CarlM.
    Regular Member installer's Avatar
    Nottingham
    Just to say I` had this to day, scratching my head what could it be,I know vectra-c and bingo.Pull the shield back and a stone falls out, with other bits.So currently squeak free.
    gy
    Default Thank god!
    After having new pads and discs - then going round every wheel and checking pads, greasing back plate etc.......................still squeaking
    Quick google - Vectra C forum, went outside, put on full lock and rammed a screw driver behind plate................jobs a goodun
  1. metallic scraping noise when turning left
    By brasch in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2013, 01:07
  2. High pitch noise
    By shaun_richmond in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 19:46
  3. high pitch squeal coming from front??
    By KevinG in forum Engine & Drivetrain
    Last Post: 28th February 2009, 17:42
  4. Metallic noise when turning
    By Dwabo in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2008, 19:56
  5. high pitch noise
    By tjsingh in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2008, 09:49
vauxhall insignia high pitched noise
vectra c squeeking rear wheel
https:www.vectra-c.comforumshowthread.php47880-Metallic-High-Pitch-Squealing-Noise
high pitched noise when car going round a bend
high pitched metallic squeal
opel vectra high pitched squeaking noise
high pitch noise on vectra
hi pitched noise on vauxhall insignia
high pitched noise from Insignia
vauxhall vectra high pitch noise
