Thread: Where's Your Clutch Bite Point?
    Regular Member AntB's Avatar
    StatsVehicle Info
    Default Where's Your Clutch Bite Point?
    Just curious as to where people's clutch bite points are. If 0% is pedal not pressed & 100% is pedal to the floor.
    The reason being I've just had my dmf, clutch & slave cylinder replaced due to a faulty dmf after 30k, before the repair my bite point was around 40%, now it's down low at about 80%.
    I know it's all hydraulic & non adjustable, and I was assured it's been properly bled out and is just a case of it bites where it bites. I'd be interested to hear other people's thoughts.
    PS, might be worth mentioning the miles your clutch has done.
    Surrey
    StatsVehicle Info
    I thought if it bites near the top its on its way out. My girlfriends Puma had done 50k and was biting at the top and when replaced it went right to the bottom. It was so bad I couldn't get up a steep hill near work, I don't know how she didn't notice it slipping.
    Just test the clutch 1st gear and handbrake on it should stall or floor it when driving along in 4th say, revs should rise too quick.
    Regular Member cbee101's Avatar
    Apr 2008
    Blackpool
    StatsVehicle Info
    80% ie 20% from the floor is too low. sounds like it either isnt bled properly or one of the push rods is too short.
    Chelmsford
    StatsVehicle Info
    I find mine has a very long bite. It starts at about 80% and is fully engaged at about 10%.
    Sometimes get aching knees due to the long travel of the pedal, so would love to find a way of the getting it to only reach full disengagement when it hits the floor.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    StatsVehicle Info
    Approx 50% in the GSi 30K miles.
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    StatsVehicle Info
    i would say mine is is about 55% on a 3.0v6 cdti with 54k on the clock
    Regular Member Matty H's Avatar
    Bristol
    StatsVehicle Info
    Around about 50% on a 2.2 Direct Petrol with 2k on the clock
  1. Replies: 26
    Last Post: 1st March 2012, 20:49
  2. Clutch Biting Point
    By si_hoss in forum Engine & Drivetrain
    Last Post: 16th March 2011, 10:08
  3. Very high clutch biting point
    By NikNaks in forum Engine & Drivetrain
    Last Post: 24th February 2010, 13:46
  4. 314 Set Up Lacks Bite
    By maxcars1 in forum Handling & Braking
    Last Post: 22nd October 2008, 18:53
  5. Clutch Bite Point....
    By Signum_CDTI in forum Engine & Drivetrain
    Last Post: 10th December 2007, 01:01
vectra c high clutch peddle
vauxhall vectra clutch bite
insignia short clutch bite
vectra clutch bite high up
vectra c clutch high
Vectra c high bit point
vectra c mileage for clutch change
vectra 2.2 direct clutch
vectra c clutch biting point
