Results 1 to 10 of 14
Thread: sun visor and interior light
    Regular Member Peabrain's Avatar
    Apr 2008
    Purmerend (Holland)
    Default sun visor and interior light
    Hi guys,
    I want to replace the standard one bulb interior light and the sun visors in my 2005 Vectra C for the ones with reading lights and sunglasses case and visors with lights.
    Anyone experience with this ?
    Is there already wiring in place for that or will it be much more trouble ?
    Thanks for the help.
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    A lot of people on here have done this. I pretty sure its a case of get the parts, plug & play!
    Sunny Dartmoor
    If you haven't got the loom for the illuminating sun visor's then just wire them to the ciggy lighter,sunglass holder is just straight swap.........
    Here's mine all done.....
    http://www.vectra-c.com/forum/showpo...95&postcount=1
    Apr 2008
    Purmerend (Holland)
    Thanks for the help guys ! Replaced the interior light thingie with the one with reading lights and sunglasses holder. With sweaty handpalms I must admit but within 20 minutes the old one was removed and the new one fitted. Indeed a straight swap although you needed an extra part to fit against the roof. Needed for fitting and securing the sunglasses holder with 2 screws.
    Sunny Dartmoor
    Mine just clipped in........
    Apr 2008
    Purmerend (Holland)
    Quote Originally Posted by glenboy View Post
    Without the extra part the sunglasses holder just fell out. In my case it didn't click in it had to be fastened with two screws. Maybe the part evolved over the years ? Got mine this week new straight from the Opel dealer. Stupid, should had made pictures
    Sunny Dartmoor
    Pic's are always nice......
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Quote Originally Posted by Peabrain View Post
    Mine's fell out a couple of times now as well. Did you have the black plastic backing in your roof?
    Apr 2008
    Purmerend (Holland)
    Quote Originally Posted by lofty View Post
    Yes, you slide it in and has pins on the roofside. When you take a look at your roof you'll see a small hole in the front and in the back. The one in the back is about 20 cm's under your lining. The plastic backing has two pins which fit in the holes in your roof. Those prevent the backing to slide to the left or right. In the backing ar three holes where the standard screws in the front come through.
    I felt a bit guilty not taking any pictures of my "project" so I've been searching the Internet and guess what I found : a picture of the thing !
    On the picture you look at the top of the backing.
    I've indicated with the two arrows the two plastic parts where you attach your sunglasses holder with two screws (not to long otherwise you'll damage your roof !). Opel partnumber : 24446892 (don't know if Vauxhall uses the same numbers) and it's called : reinforcement. Hope this helps.
    Sunny Dartmoor
    Thanks for that mate,might get myself one just to make sure it don't fall out,cheers.......
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  3. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  4. Interior light
    By johncharles in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2009, 20:51
  5. interior r/light
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2008, 19:44
