Thread: Spoiler Painting
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Spoiler Painting
    spoiler should be here today and after a ickle advice and words on the price of respraying..and fitting a rear spoiler..would like it done before PVS..but depending on cost..we will have to see bout that..
    rough price??..
    Sunny Dartmoor
    I'd say no more than £60.........
    came before..little bit of damage where the screws go in..(cracked).. should be fine with some filler.. might end up just getting it bonded on if its sturdy enough then..
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Cant beat fitting it properly tho...
    IMO You should get it fitted the way it was built to be. If they told you to glue it on then fair enough but if its got the bolts then do it properly
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Always have that satisfaction that its fitted properly. Not worried it could come off any second while on the move!
    Dwabo..just bonding it won't hold it on. it's gonna HAVE to get bolted on.....so it's get the drill out time..
    hmm..could be a prob then..one of the bits where the bolts go has split..so could be a ickle problem..will see what a bodyshop can do with it..
    Chelmsford
    Which spoiler is it? I've got the irmy style one and it's not bolted on in the centre (because i couldn't be bothered to remove the boot lining!), works fine with only 4 of the 5 in place.
    the outer edge one..where the 2 bolts go in..basically one of the threads is split..maybe it can be filled and then new bolts drilled into it..will post some pics 2moro...
    seller says i can have a refund if i send it back..will take it to a bodyshop and see what they say..it is only minimal so should fix no probs..
  1. irmscher spoiler painting
    By macka85 in forum Styling
    Last Post: 28th January 2010, 08:57
  2. painting xp spoiler
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2009, 18:54
  3. spoiler needs painting
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2008, 00:15
  4. Painting and attaching a spoiler...
    Last Post: 7th March 2008, 17:06
  5. spoiler painting
    By fixerman in forum Styling
    Last Post: 12th May 2007, 18:10
