Thread: 2.2 dti misfire hesitation on accelaration
    New Member ANDYS7571's Avatar
    worcester
    Default 2.2 dti misfire hesitation on accelaration
    my 2.2 dti has a problem , when i accelarate the car loses power and hesitates, and ecu light comes on for few seconds and goes back to normal before hesitating again, normally happens between 2400 and 3500 rpm, also kangaroo's from standstill on roundabouts, only occasionally though, any ideas anyone, its fine if you drive like a grandad, only when you want to give her some beans it does it
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    sounds like it could be the MAF, get it on a comp asap
    Full Member Big Sig's Avatar
    2.2dti? check the boost hoses!
    worcester
    what for leaks, one's from turbo or wastegate vacuum hoses
    worcester
    found out the problem that vauxhall did not, wastegate vacauum actuator bolt loose and fell out, which stop the wastegate actuating, thus stopping boost
  1. Misfire/hesitation - an update.
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 8th December 2011, 19:40
  2. Y30DT - misfire/stumble/hesitation etc, etc..
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 25th November 2011, 20:06
  3. Hesitation help
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 21:53
  4. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  5. Intermittent hesitation / misfire / fuel starve
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 10:35
vectra 2.2 misfire dti
vectra dti hesatates when started
vectra dti misfire
2.2dti missfire
2.2 dti missfire
