Thread: Insp message
    May 2008
    LEEDS
    Default Insp message
    Hi guys, I'm not sure I am on the right forum but will post this anyway, I am getting a message on my speedo mileometer that says 'Insp' when i turn my ignition key anyone know what this means?
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    Due a Service/Inspection!
    Jul 2006
    Mexico
    the beast needs some attention
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by chrisschild View Post
    m8.........
    EVERYWHERE
    If you've already serviced it recently,you can remove the message by putting the key into the ignition,press the brake pedal and press the 'trip' button on the instrument panel at the same time,then turn the ignition on (don't start the car,but keep pressing the brake pedal and the 'trip' button) and then wait for around a minute or so for the process to complete,remove foot from brake,remove finger from button,switch off ignition,job done.
    Jul 2006
    Mexico
    Quote Originally Posted by diesel dog View Post
    Hey! you should charge a couple of GBPs for that info on Ebay mate
    EVERYWHERE
    Quote Originally Posted by BlueRob View Post
    It's common knowledge around here.There have been threads about this before.
    11 Post(s)
    some people do. Some also charge for info that's readily available in the handbook, such as autolocking, etc.
    EVERYWHERE
    I should say that on some models you can get away with just pressing the button on the instrument panel in and switching on the ignition.Also,some models require the side-lights to be switched with the button pushed in and then turning on the ignition!
    Try them all,It'll work eventually.
  1. On start up - InSP or INSP
    By Carl83 in forum Engine & Drivetrain
    Last Post: 27th July 2011, 12:48
  2. insp message on odometer display
    By al21784 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2007, 00:27
  3. INSP Warning Message
    By bennyk in forum Engine & Drivetrain
    Last Post: 13th February 2007, 20:05
  4. Insp message
    By Neil in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2007, 10:33
  5. Insp
    By ZC_74 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2006, 21:55
