Thread: suspension or steering problem?
    london
    Default suspension or steering problem?
    hi,
    my vectra 1.9 cdti 8v has this clunking noise when pressing and depressing acelerator and it comes from engine area and i can hear it no matter the speed. also i have the usual knocking noise form front and rear of car when going over bumps.i also have a problem when braking the car turns to the left though the steering wheel is locked.
    any help will do!
    thanks
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by xaviroller View Post
    hi,
    any help will do!
    thanks
    Sounds like you have a couple of issues
    Blue Bold sounds like Engine/Gearbox Mounts.
    Green Bold sounds like Drop links
    Black Bold i don't understand How can you drive the car with the Steering wheel Locked, You need to have the Ignition Key removed for that to happen !!!!
    Dean
    Regular Member djr69uk's Avatar
    Midlands
    i'm thinking track rod end or lower arm bush split... that would explain the pulling to one side when braking too. i assume you meant braking in a straight line.
    Midlands
    meant ball joint, not track rod end
    london
    thanks guys for the help!
    my mechanic was a bit lost with all these problems , so this extra help may save me a lot of time am money.
  1. Knocking in suspension / steering.
    By lh_4827 in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2013, 21:48
  2. Suspension / Steering
    By moneypit in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 19:31
  3. Suspension problem
    By Fishmichael in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2011, 21:29
  4. possible suspension problem?
    By Big Knox in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 22:22
  5. Suspension & Steering Noises
    By phil79 in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2009, 00:29
