Results 1 to 10 of 13
Thread: flat spot???
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    Default flat spot???
    Ive had my 1.8 04 vec for 1 week now and have noticed its got a flat spot between 1000 to 2000 rpm, especially when pulling away quickly. Any ideas/remedies appreciated..
    Also I know this isnt the electrics section but sometimes the head lights seem to dim after just starting and pulling away and when selecting reverse...weird or what? It seems to be related to when I let the clutch pedal out...any ideas anyone
    Cheers...Bob.
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Had something similar with a Zafira 1.8 16v.
    It felt like the traction control - I.E you try and boot it and it cuts in - thus getting a sort of hesitancy on the acceleration - hated it!
    Have you taken it to Vx dealer for them to check for error codes?
    For the flat spot, a K&N makes a huge difference, along with derestricting the airbox, or it does on a 2.2 ...
    Smile
    Ive got a 1800LS (ish) and i had a bl**dy horrid flat spot.I got rid of the airbox and filter and replaced with an induction kit ( my bruv-pioneer- replaced his panel filter with a k&n filter and modded the box and his flat spot has almost gone,).Took off the exhaust and replaced with powerflow pipes on "both" sides..It has improved by 90%, so,so much better..
    Jan 2006
    Durham...
    Thanks very much for the help gents..I think Im gonna try a k & n panel filter..as for modding the air box Im not sure how its done??? Is it some thing to do with the removal of part of the air intake inside the box??? any hints or help appreciated... (again!!!!)...
    and....anyone have any ideas about the lights...they still seem to flicker.it mainly affects the head and reverse lights when letting the clutch out...weird...!!
    The top of the airbox needs cut back a bit, with a dremel or similar. The bottom pipe just clips out. If you don`t have a dremel Abyss will show you how to do it with a sledgehammer and wooden spoon
    Sunny Aberdeen
    Jan 2006
    Skynet HQ EMEC#5
    Another filter panel option is one by ITG (foam) that's what I fitted to my 1.8.
    They had to make it, cost last year was approx £40
    Also removed bottom pipe piece.
    Jan 2006
    Durham...
    Quote Originally Posted by Bainie
    Thanks very much...I should be able to manage that .. It took me 2 hours to put 4 wheels on the other day..Not that im a numty, its just I havent used a spoon or a sledgehammer on cars for years.... cheers, Bob
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
  1. Flat spot :(
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 19:06
  2. Flat spot
    By marc vectra sri in forum The 'Off Topic' room
    Last Post: 12th August 2012, 19:38
  3. flat spot but different
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 28th July 2012, 11:40
  4. Flat spot!
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 09:43
  5. flat spot
    By surreyl31 in forum Petrol Engine related
    Last Post: 16th July 2007, 18:41
