Thread: 1.9 CDTi MISFIRE
    Oct 2007
    Sussex
    Question 1.9 CDTi MISFIRE
    Hello everyone,
    I've got a 54 1.9 CDTi150 Signum (manual). Whenever i start the car from cold and let it idle for a few seconds it seems to chug a little, almost like a small misfire. It goes very quickly, usually after 10 seconds or so, or if you drive straight off. I think i've read somewhere before that this might be the Injector wiring.
    Anyway, my car has been sat for a week with no use, and when i started it, it was chugging more than usual, and when i drove off it was running on what felt like 3 cylinders with very little power, once i'd driven 50 or so metres it cleared itself with no further problems. No management lights came on or have been on since...
    Does anyone think the injector wiring could be the cause, or just that it's been left for a week..? i always use Shell V power diesel to keep the injectors and such clean....
    Many thanks.. Dave
    Regular Member vec1975's Avatar
    West Midlands
    I've had similar problems with my 1.9 120.
    I've had the injector loom replaced, 4 injectors replaced, the EGR Valve replaced, a software update and 4 new glow plugs.
    Finally it seems to be running like a dream again! (Apart from a little spilt diesel smoking but been told that will burn off!)
    Regular Member installer's Avatar
    Nottingham
    Quote Originally Posted by GSiSnash View Post
    Hello everyone,
    Many thanks.. Dave
    This was the explanation I was told of -
    Bad idle behaviour after cold start at low ambient temperatures.
    Cause: At low ambient temperatures a low battery voltage (<*1*>Due to low voltage the real injection quantity might not follow exactly the desired injection quantity. As soon as the battery voltage exceeds the values of 12 Volt or as the engine warms up (lower injection quantity) the idle speed quality will improve. Low voltage is caused by load response behaviour of the alternator, e.g. alternator need 1200 1/min initially in order to "start working". Once the engine was started and reved up > 1200 1/min the idle speed will stabilize w/o any cut offs. Problem might be reinforced as more electrical devices (auxiliary heater) are equipped to the system
    some peeps have had alternator problems and was a recall/reworking of some but from what I can gather it`s a feature of some cars,been discussed on here before
    Oct 2007
    Sussex
    Nice one, thanks very much for the reply...
    Dave
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by installer View Post
    Sorry to drag up an old thread, but recently my car has started to misfire for about 10 seconds when starting the car (but the very first start of the day) then it will be as smooth as a babys bum, I did a search and brought up this thread.
    Can anyone back the above comment up, and if so, what would be the more likely cause, the battery or alternator..?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I can only speak from personal experience with my 1.8 petrol.
    The charging circuit does not need 1200 rpm for it to kick in. After initial startup and idle stabilisation, it starts to charge - after about 3 seconds from first crank.
    I would seriously doubt that injector firing is so adversely affected by low battery voltage - when the same battery has just cranked and started the car.
    My bet would be something with the wiring and connectors - first port of call.
    Starting and charging plots here: http://www.vectra-c.com/forum/showthread.php?t=74787
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Ste View Post
    Damn it, I've been sussed.
    I have just changed the 3rd injector with the new kit from Vauxhall, but as I have no soldering iron, the wires have been joined by other means
    Oct 2007
    Sussex
    Well i must admit that i haven't got the Signum anymore, but the symptom did go away, after of all things - having the inlet manifold replaced.
    The linkage bar had fallen off on those dreaded swirl flaps. When i got the car back it never juddered again, and funny old thing, didn't get any exhaust fumes in the cabin as it used to...
    Not that i would advise to just go and get your manifold changed mind.....!
    Maybe it was a coincidence......
    Good luck..!
  1. Misfire 1.9 cdti 120
    By matt2002 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 08:38
  2. misfire on a 150 cdti- help pls
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 11:21
  3. CDTI 150 'misfire'
    By lesj in forum Engine & Drivetrain
    Last Post: 12th February 2010, 22:30
  4. Misfire on CDTI SRI 1.9
    By Warrenmole in forum Engine & Drivetrain
    Last Post: 3rd August 2008, 21:06
  5. 1.9 cdti misfire
    By johnboycdti in forum Engine & Drivetrain
    Last Post: 10th March 2007, 10:37
vauxhall zafira diesel 2007 misfire
vectra c 120 1.9 cdti misfire
misfire on 1.9cdti
vauxhall vectra c 1.9 cdti misfire
vectra c 1.9 cdti 120 misfire
zafira 1.9 CDTI missing on start
vauxhall vectra 1.9 cdti misfire
vectra c 1.9 cdti slight engine chugging
vauxhall vivaro 1.9 cdti misfire
vectra 1.9 cdti 2004 sigh misfire
Vectra 1.9 misfire at 1700 rpm
vayxhall 1.9 cdti missfire and smoke
vectra c 1.9 cdti misfire then cut out
vauxhall zafira b 1.9 diesel missing
vauxhall 1.9 cdti smoke and rough idle on start up
vectra cdti slight miss
vectra 1.9 cdti missing
vectra c 1.9 low rev misfire
vectra c 1.9cdti 120 firing sequence
vectra 1.9 misfire at low revs
vectra c 1.9 misfire
zafira 1.9 cdti misfire and smokes at idle
diesel misfire low revs vectra c
