Thread: airbag cpu removal
    Dec 2005
    south shields
    Default airbag cpu removal
    hi, does anyone know how to remove the airbag cpu from my vectra? i can see it bolted to the car under the cupholders but i cant seem to budge the thing. any ideas?
    thanks!
    right.. disconnect the battery and leave the car for 15 mins.
    remove centre armrest assy from car..remove cupholder assy.
    there are two connections.. both with swingaway retaining clips..not which one goes where....
    it's held down with 3 nuts ( 10mm) and they are a git to get to..not where the earth wire tag goes as well.. remove old ECU and Install new ECU, following the notes on what goes where. note the advice on the ECU about which plug to connect first. refit cupholder/centre arm rest.
    The Airbag ECU needs programming now..which either needs vauxcom or tech2..so it's off to a freindly dealer or local garage to get the job finally done and the light put out....
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do u need a new one as I have one available. Let me know your part number if you do and ident code (the two capital letters on the module)
    Regular Member CdRsKuLL's Avatar
    Aug 2007
    Bolton
    My car was flood damaged when I took mine to have the air bag light reset they said I needed a new module.. :-(
    have just taken mine out and its got DW on the sticker... would your spare work ? if it will how much do you want for it ?
    cheers
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Mine has GP on it so it will not be suitable, shame
    a new unit is around £300 so take care when ordering..
    Dec 2005
    south shields
    thanks mark, im gona get round to it soon. cheers for the advice.
    btw i was planning on sending mine away to get recond, not sure if it will need tech 2'd when it comes back?
    lee
    if you send yours away to get it reset ( if it will as they do suffer from board failure) then they may well wipe it..Worth a call to find that out first..
  1. Side airbag removal help
    By smitd004 in forum Bodywork & Interior
    Last Post: 21st April 2011, 10:14
  2. Airbag removal, please help.
    By tammyman09 in forum Bodywork & Interior
    Last Post: 26th February 2011, 14:21
  3. Airbag badge removal?
    By jamesr in forum Styling
    Last Post: 15th June 2008, 10:49
  4. Help, airbag removal etc...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2007, 00:02
  5. airbag removal
    By TonyR999 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 16:50
