Thread: signum 2.0dti V rated tyres
    worcester
    Default signum 2.0dti V rated tyres
    The car spec says W rated can I use V rated?
    Thanks in advance anyone
    Full Member Big Sig's Avatar
    V & W are the speed rating so I guess so as long as the load rating is correct. V is 150mph i think, W is 168 mph????
    worcester
    Tyres are 215/50/17 91V for any ones info. The reason for the check is the local tyre place can not get W rated and can only supply V rated. They are cheaper by £10 and I need three.
    sunderland
    If you're going to change speed rating change all 4 tyres as it would fail a MOT with different speed rating on same axle, ie V on N/S and W on O/S.
    Apart from this there should be no problem going from one to another.
    worcester
    100% mot failure is this true, it will help the choice if four required.
    The garage did not not seem to have a problem with the mix of ratings as I did ask for three at the time.
    Thanks for replies so far.
    Go somewhere else! get the matching ones
    6 Post(s)
    Quote Originally Posted by jstal40024 View Post
    Change the size for 225/45/17's. Do a forum search. They'll be cheaper as there is more choice as it's a more common size tyre. Also as yours is a diesel, due to the extra weight you *might* well require W rated and not V rated. Due to the slightly smaller diameter of the tyre the speedo will overread by approx 3 mph. ie, at a speedo indicated 70mph, you'll be doing something like 67mph.
    Lastly, don't bother buying tyres from a garage. Get them from one of the many online suppliers and you'll save yourself even more money.
  1. Vectra 2.0dti 16" Tyres?
    By Thom in forum Suspension, Wheels & Brakes
    Last Post: 14th November 2010, 19:28
  2. Up rated Springs
    By Stephen S in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2010, 05:25
  3. which rear tyres for 2.0DTI Estate??
    By mick 1986 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 19:44
  4. Can i have ZR rated tyres fitted ?
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 02:30
  5. x rated post man pat
    By trucker in forum Comedy & Humour
    Last Post: 9th March 2007, 15:11
v rated tyres
