Results 1 to 3 of 3
Thread: Judder / Bang / Knock - When cold
    Jan 2008
    West Wales
    Default Judder / Bang / Knock - When cold
    Hi,
    Question around start up from cold.
    When cold the car is a little lumpy at tick over which seems to be causing a knocking noise - looks like the rear gearbox is causing this? Soon as you start driving for a few mins the noice is gone and idle is smooth again.
    I think it may be a very slight mis-fire when cold?
    Nothing to worry about just wondered if anyone else had seen or heard of this?
    Engine is a 67K 150Cdti FVSH
    Kind Rgs
    Bobby
    it's not uncommon for the 150 to run very rough when cold.. our old 150 ran like it was on 2 clyinders for about 2 mins then 'magically' ran fine...VX could/would do nothing about this under warranty but mysteriously it only started after the DPF software upgrade..in the end we dumped it and bought a 2.8T instead..
    If it sounds like the engine mount is worn then get it looked at, or it could be the DMF, but either way i'd expect it to rattle hot or cold..
    one to be looked at on a ramp from cold..
    Jan 2008
    West Wales
    Tbh, it's not something that I notice - can't even hear it in the car - but you are right about the worn mount i think. Only notice it if you idle when first started and with the price of Diesel I don't like to idle to long - need to get my monies worth!.
    Funny enough on search if seems the problem with Cdti's lumpy cold idle relates to the common rail voltage drop at low rpm..... I had a spanner light a while ago which pointed to the common rail pressure sensor issue (cleared and not come back) but I wonder.........
    Rgs
    Bobby
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. 07 Vectra CDTI 150 judder on cold start up
    By andwat in forum Engine & Drivetrain
    Last Post: 1st August 2009, 11:25
  3. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
  4. Front bang/knock noise on turning wheel
    By NPS in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2009, 19:58
  5. Cillit Bang,BANG,BANG...
    By kgsric in forum Comedy & Humour
    Last Post: 10th December 2007, 22:39
