Thread: Hand brake indicator light
    Regular Member Padster72's Avatar
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    confused Hand brake indicator light
    Hi,
    Noticed today that the dash indicator to show the handbrake is applied is not lighting up. It seems that the bulb is ok, as when I turn the ignition on, it lights up.
    I guess this means that the switch in the handbrake lever is at fault. Does anyone have any idea how to get to the switch, and how to repair it?
    Regular Member Gordon B's Avatar
    Jan 2008
    Washington
    Am I missing something, I thought the lights don't operate until the ignition is switched on, otherwise the handbrake light would be on all the time the car is parked.
    Gordon.
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    The light doesn't come on when the car is running and the handbrake is applied. But it does come on with the other warning lamps for a few seconds when the ignition is first switched on.
    11 Post(s)
    Reason it comes on for a few seconds when the ignition key is turned is that it is also the low brake/clutch fluid warning light as well and comes on as a check light.
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    It is also meant to come on when the handbrake is applied though, and it doesn't.
    11 Post(s)
    Sounds like a faulty handbrake switch then.
    May 2007
    Marchwood
    Vehicle : Insignia
    Trim : 160 SRI Nav
    Engine : 2.0 CDTI
    Year : 2010
    Indeed it does! Anyone know how to get to the switch, or how easy it is to repair?
  1. Hand Brake
    By crispy007 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 18:05
  2. Brake light fault indicator.
    By Ste89 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 18:15
  3. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
