Thread: rca converter for fitting sub to cd70 nav
    Full Member lochgilp's Avatar
    argyll
    Default rca converter for fitting sub to cd70 nav
    Hi Folks i bought an rca converter so i can add my active sub to the cd70 nav model, i was wondering where is the best place to tap in for the wiring for eg the back of the headunit or closer to the rear speakers??
    As always thanks for your help in advance
    Feb 2006
    Dorset
    back of the hu is easiest and just run the rcas back .
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i brought some from halfords and it says to tap of the rear speaker wires
    argyll
    Thats where i got mine aswell mate i was wondering if it would be easier to attach the converter to the rear speakers under the door sills or something cant be bothered having to take my headunit out again it took me long enough to gety it back in when i fitted my parrot
    Feb 2006
    Dorset
    do it at the hu , unless you want to run wires from both sides to the boot then into your convertor , at the hu all the wires are there then its a simple case of running the rca's back , the radios pop out a pop on the vauxhalls , not sure why you had any probs , if you do remove the glovebox and give the radio a push !!
    argyll
    ok lads, thanks for your help
    Regular Member SRIDAN's Avatar
    Out in the Estate
    5 Post(s)
    Vehicle : Sri Estate Navi xp2
    Trim : Leather
    Engine : 1.9 + a little extra
    Mileage : 80,000
    Just about to do this and wanted to know if i connect direct to the head unit on the rear outputs will this affect the rear speakers??
  1. Fitting a sub to cd70
    By Keith Fusco in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2012, 15:03
  2. fitting a cd70 how long?
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 23:36
  3. CD70 fitting
    By leonvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 23:54
  4. Help fitting the CD70
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 11:09
  5. CD70 fitting help!!!!!!!!
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 21:22
