Thread: Meta reversing sensors HELP lol
    Regular Member eaglepva's Avatar
    Up North
    Default Meta reversing sensors HELP lol
    I have just fitted the meta number plate reversing sensors to my siggy but i am having trouble getting them to work. i dont know how to connect them to the reverse light and i dont know which wire to connect it to can anybody help how do i tell which is the reverse light cable i have read a few threads which say its the black wire with a strip of white but i have 2 of them colour wires lol.
    Any help appreciated.
    Aberdeen
    If the siggy lights are similar to the veccy, then the reverse light is the bottom most wire on the connector block. I just put the live wire in the connector then used a hot glue gun to ensure that the wire wont come out, then connected the earth wire to one of the bolts that holds the light cluster in.
    Regular Member Paulsvectra's Avatar
    Northumberland
    Devon
    Why not take the LHS rear light out, 2 large knobs/nuts iirc, and then remove the lamp holder 'plate'. Look to where the white lens bulb is located, follow the connection strips on the lamp holder and find the wire connected to it! Easy, just takes a little perseverence to follow the connections and find that wire!
    If you connect up by the lighting plug near the lamps you can't go wrong.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I've just bought some of these seriously cheap off eBay so I'll be interested to see how you get on & how good they are
  1. Meta reverse sensors.. ANY GOOD???
    By degsy1234 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2011, 13:13
  2. fao... those with reversing sensors
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 22:20
  3. Reversing sensors
    By d16wal in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2008, 17:21
  4. Anyone fitted Meta Targa SR2 Number Plate Parking Sensors
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2007, 17:28
