Thread: Emission control light on
    Regular Member PeteRs's Avatar
    here or there
    Default Emission control light on
    Hi my car has been parked up for 3 weeks when i started it noticed a light on checked the manual its the emission control light (bottom far right) car drives ok still but think fuel economy is worse it doesnt smoke do i have to go vauxhall or is there something i can do to rectify it thanks
    Surrey
    Mine came on the other day as I reversed right up against a wall and idled for a bit. I disconnected the battery for 30 mins and it didn't go away. I refueled and it went.
    here or there
    so if i disconnect battery it should go away? i'll go try this 1st thanks
    Feb 2007
    North west
    Try this first, Put key in & turn on till light is on. Press and hold mileage trip reset button. Turn off for a couple of seconds then back on while keeping the button pressed for at least 3 more seconds. Light should reset. Start the car as normal light will come on again if a fault exists but not if its cleared.
    here or there
    okay light is now out after disconnecting battery for 30mins so does this mean theres no fault ta
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    it means the fault is no longer registered to the ECU
    If there i a problem it will come back.
    Id get in contact with MIj about the remap if its emission control
    Surrey
    My light has come back on so off to the stealers.
    here or there
    Ok car been running ok today no light but will give them a call tomorow & see what they think strange why its happened since it been parked up for 3weeks i did have small problem though few weeks back that seem to sort itself so maybe there is something lurking in there thanks
  1. Evaporative Emission Control?
    By kel123 in forum Engine & Drivetrain
    Last Post: 31st August 2011, 19:07
  2. Emission control fault.
    By rogerp in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 17:05
  3. vectra c emission control system fault
    By cmh1990 in forum Engine & Drivetrain
    Last Post: 21st July 2010, 20:12
  4. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  5. Emission control light
    By CodeV in forum Engine & Drivetrain
    Last Post: 25th September 2008, 22:55
