Thread: washer pump
    Regular Member cdms811's Avatar
    Newcastle
    Default washer pump
    is the washer pump covered by warrenty?
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    nope and they £35.00 from vx..are you sure its not clogged up as was with mine.. after i got a new one.. got a old one in the shed if you need one
    Regular Member Craig1985's Avatar
    harwich essex
    hope u dont use washing up liquid? this settles at bottom of pump and blocks it and goes slimey. mine did, only used washing liquid once
    harwich essex
    always try getting it done under warranty? no harm in tryin?
    you dont get anything unless you ask
    If it's network Q then yes it will be covered but i suspect it is only blocked as the others have said !!!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    To be honest, it is so easy to check that it will be quicker and easier to check yourself.
    Just look under the front left corner under the bumper / wheel area and you will see it. Dead easy to remove, it just pulls out (IIRC) - just watch for the contents of the bottle draining out when you do...
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by cdms811 View Post
    Quote Originally Posted by simon1 View Post
    nope...
    It will be if it's faulty. If it's simply clogged up then obviosuly not and the dealer will charge a silly amount for unclogging it all for you. As the other guys said, check that first before you get stung by a dealer for doing something that's easy to do yourself.
    Can you hear the pump whirring when you use the washers?, or is there no noise?
    Newcastle
    Its whirring but no pressure at all. if it has clogged then it has done so very fast as was fine last week
    Newcastle
    Is there a How 2 for this?
  1. Winscreen washer pump
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2012, 11:51
  2. water washer pump
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 13:39
  3. Washer/pump/dohh!
    By nikroc in forum The 'Off Topic' room
    Last Post: 18th January 2011, 20:03
  4. Washer Pump
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 13:29
  5. screen washer pump
    By simon1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2008, 16:40
