Results 1 to 10 of 21
Thread: Fitted a deCAT pipe, lost power and running hot!
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    confused Fitted a deCAT pipe, lost power and running hot!
    I had a deCAT pipe fitted yesterday and as has happened when I have removed the whole exhaust, I lost power I thought a proper pipe with a full exhaust, might give a different result to just removing the exhaust but it didn't. The torque is down,the power is down, the pick up at low revs is lame but it does make more noise.... Not sure if I'm keen on the last one either
    What came as a complete surprise is that the engine is now running much hotter, around 90 deg all the time. I know it is warm outside at the moment but even with the blowers on max hot, I can't get the temp down to 85 deg when stationary!!!! I can't think of any good reason for it running so hot with the CAT out
    Fortunately it is a work in progress as I want to put a dual branch at the back and fit two sports CATs. Hopefully that should give me back the performance and reduce then noise a bit more again.
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    hmmm intresting issue. ive deCATed all the cars ive had. most were petrol mind you. the noise is normaly more raspy on petrol engines but if its a diesel engine then i cant imagine what the problem is. Id be assuming the its the same diametre as the rest of the exhaust and not to narrow.
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Same width and I can't imagine it would flow less than a CAT.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Nutron.
    I think the Temp is purely a coincidence, I have not dectaed & my Cdti 150 is now running at 90. As you say a free flowing exhaust will actually lower Egt's Etc..
    perhaps a map tweak is required to compensate as it may be running much leaner now & requires a bit more fuel
    Dean
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Ha Ha Ha Ha!!!
    Did you hear that, someone thinks my car needs more fuel!!! Ha Ha Ha Ha!!!
    No but really, Ha Ha Ha Ha!!!
    That's got to be the last thing I ever thought I would hear someone say to me Not being rude honest it's just not the sort of thing someone would say if they had seen my car on the Autobahns. I'm sure some of the wacky racers from Irmscher will confirm that I don't need more fuel
    The reason I am concerned is that the temps over in Germany during the show were at least what they are here now and I wasn't having said trouble. I do pay a lot of attention to my engine temps because of the level of tuning I've applied to it. Even on the same day before the deCAT I didn't notice such high temps.
    Regular Member cbee101's Avatar
    Apr 2008
    Blackpool
    The problem IS actually fuel related. The exhaust system with a CAT fitted has a certain "resistance" and therefore the fuel and airflow are regulated by the ECU in conjunction with the airflow meter and certain other sensors.
    The problem is you are now running lean, causing your high temperature.
    A visit to your dealer to change your ECU settings to compensate, will solve your problem.
    edit: If you continue to tun like you are now, you will burn out your injector tips!!
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I'm not running lean, I assure you. When you run lean you don't have large clouds of black behind you. I did think perhaps the ECU was trying to regenerate the CAT continuously but I wasn't sure if a CAT actually has a regeneration cycle like a DPF?
    Apr 2008
    Blackpool
    Quote Originally Posted by nutron View Post
    Whatever the case, you need to get it on the puter to see where the issue is mate.
    Nov 2007
    Staffordshire
    Ha Ha Ha Ha!!!
    Okay, Glad i amused you.
    But you have reached the limit of something !! Perhaps now your Mass Airflow is maxed out as the car can now evacuate the gases so quickly & freely, Thus screwing up your Mixtures..
    On my highly tuned cars of the past, I kept a close eye on things, You have too, But like you say, if you are certain it did not run that hot before !! then something has changed..
    Dean
    Oh, The Cat has no regeneration cycle
    Karl are you sure it's not down to the fact your car has shot piston rings buddy....Lack of compression = lack of power !!!!!!!!
  1. 2004 decat pipe.
    By sparky1292 in forum Tuning
    Last Post: 12th July 2012, 23:12
  2. decat pipe
    Last Post: 28th March 2012, 20:34
  3. flexi pipe fix and decat
    By james walker in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2011, 22:36
  4. decat pipe wanted ... bad:)
    By vectraturbocal in forum Styling
    Last Post: 9th September 2010, 07:37
