Thread: Front ashtray illumination
    11 Post(s)
    Default Front ashtray illumination
    Is there supposed to be a illumination light for the ashtray if there is only an accessory socket fitted?
    My previous Vectra (53 Elegance) had a ciggy lighter and both that and the ashtray were illuminated, but my current Vectra (06 Elite) only has an accessory socket and there doesn't appear to be a bulb or bulb holder for the ashtray. Pretty sure I once stuck my fingers down the side of the ashtray body (ashtray itself removed) and something fell off the side where the bulb should be. I've had half the centre console apart today and there are no loose wires or a bulb holder hanging down.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    My 55 plate facelift sri doesn't have an iluminated ash tray or cig lighter either as i don't smoke it doesn't really bother me.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    No, not on mine anyway. But it is easy to do: there is a white connector taped to the side underneath the ashtray. I connected one led-bulb to this illumination feed and taped it on the side behind the opening. See: http://www.vectra-c.com/forum/showthread.php?t=15999
    Regular Member Craig1985's Avatar
    harwich essex
    i haven't got one on my 07 vecy neither, wire is there tho. vx are so tight now lol
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    My early 2005 pre f/l has the all the wiring fully connected & even a bulb in the cig lighter but it doesn't work, & having tested it out it doesn't have a 12v feed to it either - all seems a bit strange & I can't really see that it can be a Tech2 opion to have it on or off!!
    11 Post(s)
    Thanks folks. I'm pretty sure the bulb holder was there before I put my fingers on it and dislodged it. I've had as much of the centre console apart as I can manage without ripping out the auto gear lever. Can't see the holder at all. Found the white connector though. It was wrapped in sticky foam and stuck to the side of the console. There is another wire which is wrapped (masking tape) to the two wires that go to the accessory socket. Presumably that's the feed for the bulb illumination if it was a ciggy lighter there?
    Not overly bothered if the ashtray can be illuminated or not. Just makes it handy for lighting up small items stored in the ashtray ;o)
    I thought it was an LED but elsewhere on here someone mentioned it was a capless bulb.
  1. front ashtray
    By rich_t4 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2008, 09:09
vectra c ash tray illumination
vectra c illuminated ashtray
is there a light in the vaxhall insignia ashtray
