Thread: NCDC Sat Nav - messed up
    Regular Member danlat1415's Avatar
    Lancashire
    confused NCDC Sat Nav - messed up
    Hi guy,
    I've got the NCDC2013 Sat Nav player built into the car, and recently, it's been acting up...
    It seems to have crashed when I was going to IKEA on day a couple of weeks back, and now wherever I am, it thinks I'm in Ashton-Under-Lyne...
    I put in a destination, and because it thinks I'm in a different place, it doesn't show any road directions, just an arrow saying "the destination is in the indicated direction". And when I press INFO which tell you your current location, it says Aston-Under-Lyne when I'm actually about 40 miles away...
    I've tried loading an old map disc (2004) to try and reset the system, but that didn't work, so I put my current disc back on (2007). All that did was update the system to use those maps.
    No matter what I try, it always thinks i'm about 40 miles away from where I actually am.
    I've tried taking the stereo out, and leaving it a few hours.
    I've even disconnected the battery for an hour. All that did was reset the radio stations.
    Is there any way I can reset the system completely so I can get it working again? I've had a mess around with the settings and I can't seem to find anything.
    Please help guys, the Sat Nav is useless like this...
    Hope you can.
    Dan
    Regular Member djr69uk's Avatar
    Midlands
    Maybe disconnecting the battery for 30 mins would help?
    Regular Member LJ sxi-nav's Avatar
    Winchester
    ahem
    Quote Originally Posted by danlat1415 View Post
    I've known a cheap aftermarket sat nav unit to do this, it seemed to have lost gps signal. was fine once the gps was re-acquired.
    There was an issue with these head units where they failed and were replaced under warranty sounds like yours has slipped through the net .....Sorry !!!!!
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    dunno..but a wild guess would possibly be the aerial reciever base unit...not bein too technically minded it may have come loose or loose wires..worth a poke round..
    have the same unit in mine.. no probs..touch wood though!
    Midlands
    Quote Originally Posted by LJ sxi-nav View Post
    ahem
    Oops! I think I'll wait for the hangover to disappear completely before posting anymore 'helpful advice'
    Lancashire
    I've managed to get it sorted now.
    I took the SatNav system out, and disconnected the receiver aerial. Then plugged the system in for about an hour, and tried using the SatNav. Did exactly the same as before, just showing the arrow, and not the actual street I was on (normal this time as I'd unplugged the aerial)
    So I took the system back out and connected the GPS aerial back in, and put the stereo back, and it works perfect again now.
    It seemed to have lost the signal when it crashed. I remember when it happened. the sound went off and the screen went blank for a few seconds. Didn't think much of it at the time, and it messed the system up.
    All working fine now.
    Thanks for the advise guys
  1. HELP!! 150 cdti i messed up
    By bingo999 in forum Engine & Drivetrain
    Last Post: 30th August 2011, 13:52
  2. site messed up?
    Last Post: 3rd June 2010, 22:18
  3. Messed up!
    By Big Sig in forum Comedy & Humour
    Last Post: 26th September 2008, 06:46
  4. elephant.co.uk messed up my NCB!
    By Vectra Singh in forum General Chat
    Last Post: 2nd February 2008, 17:29
  5. Am i messed up
    By shan in forum General Chat
    Last Post: 20th November 2007, 21:17
