Results 1 to 10 of 13
Thread: Low miles per gallon anyone?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Low miles per gallon anyone?
    First got my Veccy and was getting 450-500 miles to a full tank.....now im lucky if i get 300 to a full tank!! Today i put £50 in, have done 35 miles and its gone from full to the red in between 3/4 and full. If i carry on like that ill only be getting 60-70 miles to quarter of a tank!!
    Could this be related to the caterman box ive got on or the fact that ive done 20,000 miles and havent had it serviced....could a service really impact the fuel consumption so much??? And with the cost of fuelincreasing so much these days its getting beyond a joke.....im putting £120+ in a month!
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Hmmm, doubt missing the sevice would have such a big impact, more likely the box. I put redex in on my last fill up and have suffered just as bad, be lucky to get 300 miles out of the tank. The car is as mad as a box of frogs though, must be the redex.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    had the box off a while now and think the mpg around town is a little better, althought with the box on there is alway's the urge to plant my right foot down a little harder so deffo less mpg to be had...........
    saying that we averaged around the same mpg on a good spirited run down the autobahn's last week without the box as with it on (avv 50mpg)
    still getting around 550 - 600 per tank only the fill up has gone up big time money wise due to the robin barsteward goverment
    Midlands Mod Shop - NFFC.
    East Midlands
    If you have no reason to do so, never fill your tank up to the brim as the extra weight you are carrying in fuel adds to excessive fuel consumption,not a lot but it does add up over a period,check your tyre pressures this has the same effect,get the car serviced then you can cross that one off your list.
    Thanks all, Need to get the car service A.S.A.P should the oil be change every 6000 going to try and do the service myself.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by macdad View Post
    Interesting one - just googled the weight of petrol and 1 litre = 0.75kg. So a full tank (60 litres) weighs in at a staggering 45kg (99lb or 7 stone)
    That's a lot of spare weight to carry round - I know it decreases as you burn the fuel but it's like carrying a child around all the time and I'm as guilty as most for running with a full tank.
    Nicking Ya Dinner.
    Check the air filter
    And I'd say you are spot on with the tuning box, get it off asap.
    Quote Originally Posted by VauxVeteran View Post
    Done the air filter mod will this make me use more?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    there is an oil for the diesels which last for 18,000 miles so no need for a every 6.000 miles
    as it has been mentioned a good service and adjust the tyre pressures will help so go to your local motor factors and get oil, oil filter pollen filter air filter (unless you have a k&n fited) diesel filter and treatment (put into new filter as it cleans the injectors better should cost around £60
    Nicking Ya Dinner.
    Quote Originally Posted by vectra 120 View Post
    Na, I mean replace the dirty element, if you have done the mod wrong and too much air is getting in then I suppose it could make the engine run weak which does increase fuel consumption.
  1. Miles per Gallon
    By markf09 in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2009, 20:35
  2. Mile per gallon/miles per Litre
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2008, 19:55
  3. how many miles to the gallon !!!
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2008, 01:08
  4. Great Miles per Gallon
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 14:11
