Thread: Oil Change - 2.2 DTi
    Larkhall
    Default Oil Change - 2.2 DTi
    Can anyone give me some tips on how to change the oil??
    Checked it this afternoon and it's black!!!
    Regular Member ade's Avatar
    leicestershire
    oil in deisels always goes black real quick
    Regular Member carlton's Avatar
    Oct 2006
    Planet Earth
    Tam,
    Cant you get it done through your work (if they have a service dept)
    its pretty easy, but if your not sure you can take it to kwik fit etc who do fixed price oil and filter changes.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Its a really easy job, i did mine 2 months ago. You need a tx45 bit or a hex key and i think 38mm for the oil filter. Its pretty much the same as the how2. Only 2 problems i had was that there is a plug above the oil filter housing which you need to take out to get the oil filter changed and i couldnt move that sump plug at all! What i did was took out the oil sender at the front of the engine, let it drain and the lift the back to take the rest out.
    I used engine flush as well and think it make a nice difference, i recommend this but not everyone does.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
