Results 1 to 3 of 3
Thread: Header Tank Cap Weeping slightly !!!
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Header Tank Cap Weeping slightly !!!
    My header cap on my Cdti 150 leaks a small amount of coolant which then gathers around the level lip. I have noticed that the two O-rings that seal the lower & upper parts of the cap have become flat on the edges, instead of round/oval Etc..
    Car has done 87K, Is this a servicable part & do they become weak & leak ??
    Anybody else had this ??
    Dean
    Mileage : 000
    I belive that there is a thing about them leaking. I would think that you can get a new cap from the dealer without any problem. It would be a good idea to replace it soon as when the cooling system is under presure the coolant will leak out even faster.
    Nov 2007
    Staffordshire
    Quote Originally Posted by ed taylor View Post
    Cheers Ed.
    I have just found this whilst searching by Mr Moderator GSI3.2
    first, and most likely 'easy' cause.... change the tank cap ... they are well known for becoming weak and allowing hot coolant vapour to secape, making it look like coolant loss..
    i take it you have not other signs of trouble?..just the water going down?
    So i'll pop & get a new cap tomorrow before it develops furher when the Hot weather arrives
    Dean
  1. Possible cracked header tank on vec 1.8 sri
    By triple595 in forum Engine & Drivetrain
    Last Post: 17th February 2013, 19:22
  2. header tank cap??
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 23:15
  3. Help replacing header tank
    By watchman in forum Engine & Drivetrain
    Last Post: 28th April 2010, 12:26
  4. header tank cap
    By animal22 in forum Engine & Drivetrain
    Last Post: 6th March 2009, 14:52
  5. Header tank.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2008, 21:41
