Results 1 to 10 of 14
Thread: How much oil in an 06 1.8 vvt?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default How much oil in an 06 1.8 vvt?
    Anyone know?
    Also, anyone know of any offers at the moment on 5/30?
    & does it have to be fully sythetic?
    Cars only done 2k since the garage I bought it from changed it ( with 10/40 ), but it is looking crap, so treating it as a flush and going to put some proper oil in.
    Any tips for changing the filter? doesnt seem much room for an adjustable spanner in there?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    try here m8 as they are linked to the forum http://www.opieoils.co.uk/
    Oct 2007
    south wales
    SLIGHTLY CONFUSED NOW, THEY OFFER 3 OILS THE 5/30 IS Fuchs TITAN SUPERSYN ECOFLEX 5W-30 ? NEVER HEARD OF IT, CAN IT BE TRUSTED?ITS DIRT CHEAP AT 21.15?, OTHER RECOMMENDATIONS ARE Mobil 1 0W-40 Advanced performance synthetic engine oil AT 43.48, & Castrol EDGE 0W-30 for modern engines AT 39.75.........................
    NOW I AM CONFUSED?
    Regular Member simon5800's Avatar
    May 2007
    derbyshire
    fuchs is silkoline, isnt bad. i am just going to use the GM stuff, is 5w/30 and was only £22.50 from local spares place for 5l of it. the old 1.8 says it is 4l in the manual so huess around the same for the vvt
    Oct 2007
    south wales
    just found the manual, it states 4.5l with a filter change ( as if I am going to change the oil and not change the filter!!!! ), so one can should do. the handbook states that the 2 litre has a 6 lire capacity, must be annoying having to buy 6 litres!
    just a bit weary of buying cheap oils...
    Oct 2007
    south wales
    Default oil filter?
    Any easy way of getting an adjustable spanner on there?
    Quote Originally Posted by PeterVV View Post
    i think they are a 30/32mm
    Belfast
    Fuchs is a very good oil - as used by the government owned bus company over here. I've been using it off and on for years, and had no problems at all with it.
    Oct 2007
    south wales
    confused
    Who does make the VX one ? is it the same as the Fuchs I wonder?
how much oil fir the insignia 1.8
