View Poll Results: To flush engine or not
Voters
120. You may not vote on this poll
  • Yes flush away
    41 34.17%
  • No dont
    79 65.83%
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: to flush or not to flush
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default to flush or not to flush
    guys doin my oil change tomorrow and following from a thread i have one member sayin flush the engine and the other says not to. i bought engine oil flush from halfords but i can swap it for the stuff the vauxhall sell if that would be better. whats the general idea? also can anyone tell me the torque setings for the sump plug and the oil filter cover?
    Aberdeen
    When i done my oil change i used the Waynes petrol engine flush. Not had any bad effects. However if the car has done many miles and never had an engine flush then it may cause problems with oil leaks.
    Tyneside
    How many miles has the car done? If it's done quite a lot and you don't know what was done previously leave it! You could potentially empty your wallet very quickly if the worst was to happen i.e. you flush it and the gunk sitting in the engine blocks the path for oil.
    Regular Member mushy2007's Avatar
    Liverpool
    As mark said leave it well alone
    Regular Member oil-burner's Avatar
    Jan 2008
    newcastle upon tyne
    my engine was flushed two weeks ago when it was at stealers for its 60k service, using vx flush. no probs yet. 05 cdti 150.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    yep 60k on mine done an engine flush n oil change 2 month ago no probs at all. used slick 50 engine flush then new oil and topped up with slick 50 original. all seems good.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    i have to agree with the no flush... i used to have an mondeo company motor, ok, stop the luaghing...ford used to have on the counter a notice advising drivers to have the flush, if you change the oil every 10k or once a year, youll have no problems if you leave it for a while over 2years or 20-30k, then maybe as ford said there would be a build up.. albeit i have always serviced once a year or 10k... this rule has worked for years..
    Liverpool
    I was told during my mechanical course by an excpetional engineer and as mark said flushing a car can dislodge deposits that the car has happily lived with into the other oil feeds around the engine.
    Oil changes should be all you ever need.
    Nicking Ya Dinner.
    Quote Originally Posted by mushy2007 View Post
    That's good advice, but not entirely true, if you don't flush an engine you get build up in the cam followers and valve stems, flushing removes this and keeps the engine opening and closing at the correct times, however, I'd not do it to a car that's done 40k+ unless I knew it'd always been done.
    PM Mark GSI, I'll go with his opinion, I think he'll agree with me, but if you should do it and do end up with a disaster eventually you shouldn't hold him responsible.
    Surrey
    Some interesting reading can be found here.
    http://www.carbibles.com/engineoil_bible.html
  1. Flush what you think
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2011, 15:24
  2. will i flush her?
    By twaiter in forum Engine & Drivetrain
    Last Post: 19th March 2010, 22:32
  3. Flush or No Flush(2.2Dti)
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 20:35
  4. to flush or not to flush
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2008, 22:56
  5. Flush fit sub
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2005, 23:05
wynns engine flush corsa c
corsa c wynns flush
how to flush an 05 vectra
