Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Sport Button - Auto CDTI - Did you know!!!?
    Regular Member mushy2007's Avatar
    Liverpool
    Thumbs up Sport Button - Auto CDTI - Did you know!!!?
    Since I got the siggy over 12 months ago I was always under the impression that the sports switch under the accelerator is their should you be in low revs and want to get moving quicker you depress the accelerator then push again and the switch drops a gear.
    Anyway I was going through some keen driving in Wales the other day and put my foot down to accelerate and as usual the car changed gear @ 4000rpm, as I am going along a tractor pulled out and I coasted up to it then used the sports switch to keenly wizz past.
    But this time i left my foot down even on the switch and the car rev'd to about 4700rpm and was going like a bat out of hell!
    So i tried it again joining the motorway later on, drove with my foot down without the switch and it didnt go past 4000rpm but when the switch is down it will go to about 4700rpm which with the BSR you get some rate of nots going.
    You all may know this but I thought i would mention it as in the 12 months or so i've had it i didnt know!!! ha ha
    Somewhere I probably shouldn't be
    Sports switch under the accelerator???????
    Do you mean "Stepping down"?
    Liverpool
    Yes but it isnt just dropping a gear; the car with the button depressed will rev higher than normal!
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by mushy2007 View Post
    Is this button in existance on the Vectra CDTi 150 Auto?
    Yeah, but when you say "button" are you just referring to pushing the accelerator beyond the resistance, giving it step down. It's great that it does allow some over revving. Wonder if it gives a little overboost too.
    Liverpool
    Quote Originally Posted by Davidjs68 View Post
    Yep mines the same motor, and its a button / switch etc.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Used to be called a 'kickdown' switch,on older auto's used to just drop a gear but on a modern can-bus car it could do alsorts!.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The 'kick down' will also hold that gear for longer, ie higher RPM before changing up.
    This is not new, just about every auto has this feature, just maybe not electronically.
    Tyneside
    So is there actually a sports switch or is it just the kickdown your referring to when it's holding the revs for longer?
  1. sport button, traction control button
    By Denbro in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 23:44
  2. Re-map sport button
    By jamesgsi1983 in forum Diesel Engine related
    Last Post: 18th February 2009, 19:33
  3. Sport Button
    By V6Andy in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2008, 19:41
  4. sport button
    By stumorrison@mac.com in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2005, 20:27
