Results 1 to 10 of 17
Thread: 2.2 signum
    Jan 2006
    wales
    Default 2.2 signum
    hello all
    im new to vx and just about to buy a signum 2.2 elegance (2004)
    i would like to know what the direct means on the back?
    and also how often the cam belt needs changing?
    and also what mpg should i achieve?
    cheers chris
    The direct is to do with the injection system (IIRC) and just means it is a slightly better version of the original Vx 2.2 engine.
    Cam belt intervals for Vauxhalls are 40k or 80k, I think for the 2.2 direct it is 80k, but I may be wrong.
    Some of the chaps with the 2.2 Direct have been getting between 35 and 40 mpg, more often it is 30-35 though, its a very economical engine if you drive it gently!!!!!
    Jan 2006
    wales
    Default 2.2 signum
    cheers for the info cant wait to pick it up next week
    You'll love it mate.
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    I understand that the 2.2 direct has a cam chain - not a belt.
    Am I misinformed?
    Doug
    Jan 2006
    wales
    Default 2.2
    dont know for sure mate even better if its a chain
    Ashington, Northumberland
    Quote Originally Posted by chris&lisa
    hello all
    cheers chris
    Welcome to the site mate. As for the 'direct' on the back (direct injection), what that means is, that inside the cylinder the injected fuel is directed straight into the cylinder above the piston as opposed to indirect injection whereby there is what is known as a swirl chamber, a small recess that is machined into the cylinder head into which the fuel is injected. The indirect system causes the air and fuel to swirl around mixing together in order to permit a better flame spread within the ignition phase. With the direct injection, it allows for a higher compression ratio, giving more power. Don't know if I've baffled you here, but that's basically what it means. BTW, I'm a diesel fitter if you hadn't guessed
    Jan 2006
    wales
    Default 2.2
    all makes sence i was a car mech many moons ago before going over to helicopters (the latter is the simpler) honest
    cheers for your help
    Believe it or not I nearly chose that career in the Army, Aircraft Technician in the REME, but I thought the Tanks were a far more exciting prospect so became a Vehicle Mechanic instaead. (If only I knew then....... )
    Jan 2006
    wales
    Default 2.2
    well i dont know about the army but its not a bad job in the RAF but every one has his niche in the world as long as your enjoying things its a good life
  1. Replies: 2
    Last Post: 6th October 2012, 23:09
  2. Replies: 5
    Last Post: 5th February 2012, 20:42
