Results 1 to 10 of 10
Thread: Got a computer problem, can anyone help?
    Regular Member purple170503's Avatar
    kent
    Vehicle : Vauxhall Vectra C - Facelift
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    confused Got a computer problem, can anyone help?
    I have Nero 8 on my PC with Winrar, I've dowloaded a small file containing a .cue file along with a .bin file which I opened using Winrar ( I think!) I followed the instructions given with it to open Nero and try to burn the .cue file to CDr but each time it comes up with an error message 'unexpected file format'.
    Am i doing something wrong, I have read othe entries on the net where people were successful but I can't seem to get it to work, can anyone give me some advice?
    Regular Member Sawyer Reynolds's Avatar
    Mar 2008
    England
    Vehicle : Vectra C
    Trim : C
    Engine : 1.9CDTI
    Year : 2008
    I don't have Nero 8, but assume it's similar to my Nero 6.
    Open up Nero and if you get a little wizard at the beginning, just cancel that. On the menu bar at the top click 'Recorder' move down to 'Burn Image' then navigate to your .cue file and select that. It should then go through the process of getting you to burn the file. I don't have anything to hand to go further than that, but I can't see it being too complicated.
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    Hi, I've been trying that, it brings up the path to the file and states that it cannot open the .bin file, then another message pops up stating that it can't access the .cue file, Ive been trying this for days now and know it's something I'm doing wrong, just can't work it out!
    Mar 2008
    England
    Vehicle : Vectra C
    Trim : C
    Engine : 1.9CDTI
    Year : 2008
    Is it a file you've downloaded? If you've got a link for it I'll have a look and see if there's a problem..
    Have you tired deleting the bin/cue file and then re-extracting them from the .rar file (if I've read your post right!!)?
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    If you could I'd be grateful
    I've deleted and re downloaded, unpacked but each time I get error messages.
    http://www.geocities.com/its_yahell/toshiba_sd220e.html
    the download comes from the firmware tab
    thanks
    Mar 2008
    England
    Vehicle : Vectra C
    Trim : C
    Engine : 1.9CDTI
    Year : 2008
    Ok, I just downloaded it, extracted it and went through the above process with my Nero 6 and it got to the stage where it wanted to burn. The only reason it stopped is because I don't have a spare CD-R (or RW) to actually burn the image to. But it appears to be working for me.
    What I'd recommend is re-downloading again but saving to a different location, and then extracting to a different location, just to make sure it's a completely fresh file. Should that not work, if you can get your hands on an older copy of Nero (Like I say, I'm using 6). OR, another method could be to use a different program altogether. There'll be applications around specifically for Cue/Bin burning which may well do the trick for you...
    OR, if you're just needing the file for the computer you're currently on (Which, judging by the file download itself is unlikely), then you could use a Virtual Drive to fool your computer into thinking it's running a disk.
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    sorry to be a pain but could you talk me thru step by step what you did to get there?
    Mar 2008
    England
    Vehicle : Vectra C
    Trim : C
    Engine : 1.9CDTI
    Year : 2008
    Sure, no problem.
    A. Open Nero. (Nero 6 Ultra Edition >> Nero Burning Rom)
    B. When open I get a 'New Compliation' box pop up with several options. I just cancel that and I'm left with a grey screen with the menu bar at the top.
    C.Click on 'Recorder' and scroll down to 'Burn image'
    D. Little window will pop up for you to browse through to your files. Find the folder where you extracted the Bin/Cue file. And select the .cue file. (You'll know it's the right one as it SHOULD be the only option that's available to select)
    E. Once you've slected and opened the .cue file another window will pop up 'Burn Compliation' Select your regular disk burning settings (Personally, I have 'Write' and Finalize CD (No further writing possible) selected - Burn speed of 40x (will vary depending on your disk burning device).. A write method of Disk at Once and one copy.
    F. Click burn.
    That's where it kicks the CD out for me and tells me to put a readable disk in, but like I say, that's purely because I don't have an actual CDR/RW in my drive.
    kent
    Trim : Design 2006
    Engine : 1.8 VVTI
    Mileage : 63k
    I've just managed to burn it, thanks, I disabled a download manager as well and did it the old fashioned way..just hope it works. Thanks
    Mar 2008
    England
    Vehicle : Vectra C
    Trim : C
    Engine : 1.9CDTI
    Year : 2008
    Not a problem. Hope it works out for you.
  1. Problem with onboard computer
    By ian124 in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2010, 14:50
  2. Computer problem
    By silverhairedracer in forum General Chat
    Last Post: 27th August 2007, 16:48
  3. Fuel Computer Problem
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2006, 22:00
  4. Computer Problem!
    By Caterman in forum Comedy & Humour
    Last Post: 19th February 2006, 00:18
  5. Computer problem.
    By SCOTTEX in forum General Chat
    Last Post: 18th January 2006, 13:46
