Thread: what can you tell me about vee belt tensioners
    Regular Member Gambler's Avatar
    Jan 2008
    england
    Default what can you tell me about vee belt tensioners
    My mate has a vec c and has been told he needs to replace the poly vee belt tensioner. He does not know what it is nor what it does and why it should go wrong.
    Any ideas?
    Regular Member Nidge's Avatar
    Mar 2007
    West Yorkshire
    I've just been told the same today, I had this device changed about 2 years ago as the car was squealing when cold. Not the most reliable part as it needs to be replaced again. I've been quoted 170quid plus labour
    Regards
    Nidge
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    common prob on the 2.0tisnt it?.. mine squeeks and squeels from cold for around 10 mins before it goes away... mine needs doin also at some point!
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    v belt tensioner i believe is part of the timing belt assembly, its the tensioner that keeps the tension on the belt to stop it jumping teeth. Whilst they are doing it they must also replace the timing belt too i believe
    other alternative is that its the tensioner for the aircon, alternator and crankshaft belt...
    someone else will be along with the correct answer for sure
    [Ex]Admin Duncan's Avatar
    Nah, it's the belt that runs between the alternator, air-con compressor and water pump - nothing to do with the timing.
    EDIT: Just spotted your sneaky edit before it showed up as an edit on the post!
    Jan 2008
    england
    Thanks guys.
  1. changing seat belt pre tensioners
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 09:23
  2. 3.2 GSi New Timing Belt & Tensioners - Weird Side Effect
    By cmowen in forum Engine & Drivetrain
    Last Post: 5th February 2009, 23:18
  3. tensioners
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 17:11
