Thread: my engine rebuild (not vectra but still vauxhall)
    Apr 2008
    gosport
    Default my engine rebuild (not vectra but still vauxhall)
    There is no chance in me tunning the vectra as its the everyday car and she would kill me,so i decided to put a fewpics up of my other vauxhalls engine, the engine is a astra gte engine c20xe that i have converted to a turbo.
    engine and block have both had alot of work done to them
    the block
    new mahle pistons 86.5mm, machined for lower compresion
    steelrods
    early gte crank (standard bearing size)
    all new bearings and pumps etc
    oil pump is fitted with sbd nylon release valve and steel pump gear
    under piston oil squirters
    cometic 1.9mm head gasket
    arp 2000 rod bolts
    arp head studs
    arp mains bolts
    arp flywheel bolts
    pistons fitted but before i painted the block silver
    block painted and arp mains fitted
    head
    ported and polished by gary poole
    chamber work to bring cc of head back to standard after skim
    xe inlet and exhuast cam
    vernier pullys
    double valve springs
    steel valve caps
    steel valve platforms
    1mm oversized wasted stem 1 piece inlet valves
    1mm oversized 1 piece exhaust valves
    bronze valve guides
    new valve seats
    only pic of the head
    and some of the random other bits
    ecu
    downpipe, external wastegate and manifold
    fitted
    the inlet on the turbo is 4'' just to give you an idea of size
    and here she is all fitted getting ready for a start up
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Get on mate !!start tuning the vectra.You know you want to.
    Sunny Dartmoor
    That looks awesome,great job......
    Regular Member shawzie's Avatar
    Oct 2007
    bradford
    nice work mate that looks the nut's you gotta start on your vec and loads of how 2's
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    thats an awesome job you have done m8 what does it go like
    Apr 2008
    gosport
    Quote Originally Posted by glynn View Post
    welllll on this engine pass lol
    last engine was 0-60 in low 5 high 4 , 0-100 in 9 1/2 mile 12.6 @121mph with a topspeed inside a mile from a standing start of around 160mph
    new engine should be faster bot much more thou as there aint a massive increase in power, just more power without nitrous and a stonger engine
  1. Smoking engine after rebuild
    By G4GAV in forum Engine & Drivetrain
    Last Post: 24th June 2012, 23:25
  2. Cdti 120 engine rebuild?
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:53
  3. VW engine rebuild kit
    By Hummelshøj in forum Non Vectra C/Signum Album
    Last Post: 14th November 2011, 15:51
  4. Electronic Warning Light after Engine rebuild
    By Shaw in forum Engine & Drivetrain
    Last Post: 6th March 2011, 17:04
  5. Engine rebuild and now in limp mode
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 4th August 2010, 01:10
vauxhall vectra engine rebuild
