Thread: Vectra C rear brake calipers
    Apr 2008
    Cheshire
    Default Vectra C rear brake calipers
    Are all vectra c rear calipers of the wind back type?
    I'm about to purchase a tool you to do the job but I don't want to purchase the tool then take the caliper off and find I can simply push the piston back with my hands/clamp and the tool was not required for my type of caliper
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Rears are wind back. They have to be due to the design and operation of the handbrake - it must be able to take up the 'slack' as the pads wear.
    Apr 2008
    Cheshire
    Many thanks, tool ordered.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You don't actually need the tool.
    I successfully did mine without one. Yes, the tool will make it easier, but for how many times I would use it I decided to improvise
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Quote Originally Posted by Ste View Post
    With what?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I welded 2 pins onto the head of a large diameter short bolt to fit the caliper.
    Then used a G clamp to apply closing pressure and a spanner on the bolt head. Careful turning of bolt and G clamp wound the piston in without issue.
    Quicker than going to the tool factors for a tool, and then finding it doesn't actually fit Vectra's (Very common this problem), and certainly cheaper. Took less than 5 minutes to make, and cost nothing.
  1. Rear Brake Calipers
    By viper8 in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2012, 13:29
  2. Rear brake calipers
    By Rob h in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2009, 22:25
  3. Rear brake calipers Holden Vectra 2004
    By highmark in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2009, 03:33
what socket used to take of vectra calibers
vauxhall vectra brake caliper wind back attachment
