Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: upgrade rear brakes?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default upgrade rear brakes?
    i have noticed that some of the guys have been talkin in the 314mm thread about changin the rear brakes for larger ones and that all is needed is new bigger pads new bigger disks and different hub carriers but using the same rear brake calipers. is this correct and has anyone done it yet?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I don't know about using the same callipers but bigger discs are really only a cosmetic upgrade as 90% of the braking is done by the front brakes - I doubt anyone would see any improvement in braking efficiency by fitting larger discs on the back
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Apparently it is correct, You only need the cailper carriers and new discs, I guess that as the sizes are not that different, the standard rears on mine are 278mm (or 279mm?? ) and the bigger rear discs are 292mm.. The calipe carriers are around £34 ea from LMF.. I'll be doing mine shortly, just need to make my mind up what disc's im going to order for front and rear..
    As Ian said, its only cosmetic on the rears, my new wheels make the rear discs look small, hence why im changing them..
    Regular Member muffking's Avatar
    Hmmm. Just ordered some Vx replacement rear discs for my GSi. I've asked for them to be grooved for an extra £35, the total bill for the Vx pads & grooved diiscs is £130 delivered.
    How much more would the discs be if I ask them to upgrade me to 292mm + the caliper brackets?
    Just seen that you say the brackets are £34 each... That's another £68 + the extra cost of the discs & weight in postage
    You already have 292 rear brakes if it's a GSi !!!!!!
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by Drinky View Post
    its depends on what year the car is according to vx! my gsi was made in 03 and has the smaller i think 273mm i think he said! i wanted to upgrade the fronts and rears but the mounting brackets needed were £80 a pair
    Quote Originally Posted by vectragsi3.2 View Post
    VX are talking twoddle matey my Elite is a late 02 and that has 292 mm rear brakes the only difference was on early 3.2 engined cars the fronts were 302 then changed to 314 no difference to rear brakes has been made
    Feb 2007
    cheers mate mine need changing the end of the month will check the size before i order them! wanted to do the upgrade to the front but cant justify paying £80 for brackets so they will fit!!
    A quick test if your rear discs are vented then they are 292 mm if they are solid then they are 278mm !!!!!
  1. looking to upgrade my standard brakes?
    By VECTRA1974* in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 13:13
  2. Upgrade Brakes?
    By parapaul in forum Handling & Braking
    Last Post: 3rd September 2010, 02:54
  3. Upgrade brakes on '07 Vec CDTi Sri 150?
    By Telly Addict in forum Handling & Braking
    Last Post: 7th September 2009, 14:50
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
