Results 1 to 10 of 13
Thread: Torx size for brake caliper
    Apr 2008
    Northumberland
    Default Torx size for brake caliper
    Hi all, I went to change my pads (front and rear) tonight but noticed I needed a Torx bit. I have a set but it only goes up to T50 and sods law the caliper needs a larger size. Does anyone know what size is needed, I'm guessing T55 or T60. Also do the caliper pistons push back in or are they screwed (clockwise or anti-clockwise). My Vectra is an 05 1.8
    Many thanks
    Ninja
    (posting again as the first post timed out)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its a 7mm hex/allen drive mate. Screwed in on the rears, pushed in on the fronts.
    How 2 HERE and Here HTH
    Ashington, Northumberland
    Quote Originally Posted by ninja2111 View Post
    Many thanks
    Ninja
    That's the caliper carrier bolts you are trying to take off. You don't touch them at all to change pads, as Rushy says, it's the 7mm allen head slider bolts you take out. PLEEEASE be careful
    EDIT: Just seen you location, do you want me to do them for you. I'm a fitter for Northumberland County Council
    yep, to echo gary..Undo those torx bolts and it's a scrap caliper....the two 7mm bolts are under the plastic covers on the calipers..just undo those..
    if you don't feel 100&#37; confident, let gary have a look..
    Apr 2008
    Northumberland
    Thanks guys, I'm glad I asked before going ahead. I've changed pads on my old Primera and my lads Hyundais and Fords but never came across a setup like this.
    After looking at the images in the How2 I'm not 100% sure mine looked like these, I'll have another look tomorrow night (footy tonight ) and post some images if I'm still unsure.
    Thanks for the offer Gary, I'm about 8 miles north of Alnwick, whats your hourly rates lol - I have a son with an Astra that may need a timing belt kit changing pretty soon
    Cheers all
    Ninja
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The pics are of a GSi set up but yours are the same just smaller. The bolts as mark said are under little plastic caps, they stick out about 1cm and have a little dust cap on the end that you can remove with your finger nail, dead easy to do yourself mate, the hardest thing is getting the nasty little spring clips off and seated again. Again though mate if your not confidant in your work take Gary up on his offer, after all thats what were here for mate, to help where we can.
    Apr 2008
    Northumberland
    Finally got time to change the brakes all round over the bank holiday, I didn't have a replacement wear indicator so removed it totally (will get one next week) does the dash wear indicator need to be reset by Vx as it's still illuminated on the dash.
    Thanks for all the help guys
    Ninja
    ps. if anyone knws about Mk4 Astras please have a look at:
    http://www.youtube.com/watch?v=3QdeSe8I_Ac
    it's my sons Astra. He's only had it a few days when this noise started - booked it in next Saturday for a cam belt kit change but could it be more serious? <gulp>
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    As soon as a new Wear Indicator is fitted the light will go off automatically, because its off altogether it thinks its in a 'pad worn' state.
    With ref; to the Astra that 2nd pulley doesnt look right at all to me.. the centre shouldnt be like that...
    Regular Member simac's Avatar
    Wirral
    Quote Originally Posted by plasma View Post
    It looks like it's somehow become detached from the outer section that has the teeth on it that needs sorting ASAP before the belt slips off !!
    Apr 2008
    Northumberland
    Hi guys thanks for the quick reply. when you say may be detached do you mean the gold pulley (top right of picture marks '2'), from what I remember it looked like it was all one piece and supposed to look like that - I could be wrong though lol
  1. torx kits? most common size?
    By kalioon in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 22:51
  2. Torx bit size
    By st2malo in forum Engine & Drivetrain
    Last Post: 15th May 2011, 13:11
  3. What size Torx is needed to.......
    By peelmeister in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2011, 09:10
  4. torx size ????
    By anr_n_vec in forum Engine & Drivetrain
    Last Post: 23rd September 2010, 21:35
  5. TORX bolt size ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 15:19
how to remove rear caliper allan cap torx bolt sized
what number torx socket for brake caliper
torx socket vauxhaulll brake caliper
What size tourqe bit do you need to do brakes on vectra c
are all vectra c brake calipers same
what size torx bit for vectra c callipers
what size is the torx bit for front calipers on vectra c
vectra brake hex size
what size torx for vectra front brakes
what size torx bolt on vectra rear brakes
remove vectra front caliper
astra g caliper hex
combo van caliper torx size
brakes f30 rear torx size
What size star socket for rear brake calipers on a vauxhall signum
torx bolt size for vauxhall vectra rear brake pads
astra rear torx size socket
What size tx socket fits the vectra front caliper
rear brake caliper torx size
torx socket for vauxhall brakes
what size star sockett for vectra rear break
saturn astra brake calaper bolt size
what size torx socket on meriva rear calipers
zafira rear brake caliper torx bolt size
torx size vectra b brake
