Results 1 to 10 of 24
Thread: 314mm Discs etc
    Regular Member Perry's Avatar
    Watford Herts
    Default 314mm Discs etc
    Got hold of a set from the Saab dealer and I am going to attempt to fit them this weekend, I have the discs, calipers, carriers, pads, new brake sensor wire, new Brake Fluid and some copper grease,
    Is there anything else I may need and is there a certain order of bleeding the brakes and I assume although changing the front calipers etc the rears will have to be bleed as well ??
    Thanks for any advice.
    you'll need 4 copper washers for the banjo bolt unions.. don't reuse the old one's.. and yes.. rebleed all 4 calipers..
    get a Gunson's Easibleed and it'll be less traumatic to do at home..bleed NRS/OSR/OSF/NSF in that order.. use about 1.5 litres of fluid to change it all while you are there
    Watford Herts
    Wooosh, take it I can get these from Vauxhall?? Any idea of a part number.
    I have changed discs and pads before just never calipers etc so little nervous on doing it, but can't afford the £100 + vat a garage wants to do them.
    Have made a note on the bleeding cycle and I have an easy bleed kit somewhere, take it the pipe sits in the fluid in the pot and I keep pumping (oh er missus) until I see no bubbles in the fluid coming out??
    Sorry if sounds a bit thick
    you seen GG recently as he'll make an molehill out of this job.... it's not that hard to do, just don't cross thread the caliper banjo bolts. the easybleed uses your spare wheel as a pressure system ( at about 15psi) to help you bleed the brakes, so no pumping needed...
    Give GG a nudge and tell him i dropped him in it..
    Watford Herts
    You have lost me now!!!!!!!! Easybleed uses the spare wheel????
    Think GG may be getting call
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    also there is no need to take anything apart,,,the carriers with clipers and pads slip over the new discs just fine ...saves a lot of disasembling
    Watford Herts
    Cool, found Easy Bleed kit on Halfords for £16.49 understand now, cap goes over the fluid res bit in engine tyre deflated to around 15psi, connect bit to tyre and screw on cap this then pushes fluid through till comes out of bleed nipple on calipers. Is that correct??
    Watford Herts
    Oh and will buy a clamp thing as well to go over brake line?
    yep.. thats the kiddy..
    clamp is a good idea too..just don't pinch the hose too hard and deffo not molegrips
  1. 314mm discs
    By wullie-t27 in forum Handling & Braking
    Last Post: 19th January 2013, 03:58
  2. 314mm discs
    By parsco in forum Parts for sale
    Last Post: 11th January 2009, 22:23
  3. Replies: 1
    Last Post: 21st October 2008, 15:11
  4. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
