Results 1 to 3 of 3
Thread: Signum Brake Pipe Corrosion
    Apr 2008
    Luton
    confused Signum Brake Pipe Corrosion
    Hi All
    I was wondering if anyone has had the same problem as me. I've got a 53 plate Signum and a section of the brake pipe to the rear has corroded away. This has resulted with a lose of brake fluid. The section of pipe runs through a piece of rubber hose over the top of the fuel tank. The problem is, this rubber hose has filled up with water and causes the metal brake pipe to corrode within the rubber hose. Also, my car is not a high milage one either.
    Has anyone else had the same problem on their Signum's or Vectra's?
    nope, never ever come across that one before..
    Jul 2006
    And if he says he's never seen it, it MUST be rare!
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. brake pipe help
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2012, 08:00
  3. Brake Corrosion advisory
    By ChrisVec22 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 20:55
  4. Rear Brake Pipe
    By Dancer in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2012, 17:15
  5. Brake line corrosion
    By barry087 in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2010, 21:31
