Thread: add subwoofer to original head unit?
    Northampton
    confused add subwoofer to original head unit?
    could anyone plz help me? I want to know if there is any way I can add a subwoofer to a original head unit? I really want to add a sub but dont want to change the headunit! Is there ne adaptors which I can add? I dont want to attach it from the rear speakers!
    Please if anyone knows can you let me no!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by Niks View Post
    halfords sell some rca jack plugs which you wire into the rear speaker wires behind the head unit m8 and they cost about £6.99
    Regular Member S14RRJ's Avatar
    Lancashire
    excellent just the answer to the same question !
    Northampton
    oh rite! So this will give me the outputs I need? Also the quality be similar?
    Regular Member kpf1grandprix's Avatar
    luton beds
    was asking this before,,,but i wanted th vx subwoofer ,that you could of got as an option,,,,
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You will be no better off with these connectors than connecting the rear speakers to the high voltage input on the amp (if there are any). The sound quality will be the same, as both types will had the 'signal' through the head unit main amp, and the inherent distortion therein.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I have an rca converter fitted running a sub. I would steer clear tbh as the base is poor quality and go for a line driver instead. It has its own power source and can also run multiple amps if needed, so in affect you could run one amp for a sub and another running all the door speakers. HTH
    Northampton
    oh right! If I can get the wiring done from the front then I may consider it! I thought you had to take the rear door panels off etc but guess not! I want to get a double 12" pioneer but the qual of the sub wont be as good as the after market headunits?
    Northampton
    or is it best to change the headunit! But i dont want to take the front look away!
  1. New head unit
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 17:16
  2. New Head Unit
    By SwavGav85 in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2008, 09:38
  3. Head Unit
    By vauxhall4life in forum Electrical & ICE (including SatNav)
    Last Post: 29th February 2008, 11:24
  4. New head-unit
    By Christof in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2007, 19:35
