Thread: Abnormal engine running.
    Apr 2008
    Bratislava
    Default Abnormal engine running.
    Hi All,
    I bought a brand new Opel Vectra Caravan, 19 CDTI, 120HP one month ago.
    I have 3500 km today.
    My car engine is not running normaly I think. I will try to describe it.
    It looks like the engine is switching between two running modes.
    1. Drive on straight road. Speed 60km/h, speed gear 4, instant consumption around 5 liter.
    2. The same road , same situation, but the noise from the engine is bigger, and instant consumption is around 10 liters....
    My car is switching between this two modes too often. No check light is luminary.
    Had somebody the same problem ?
    Thank you
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Sounds like it could be the DPF
    Apr 2008
    Bratislava
    I read it.... I don't thing that is PDF in my case. I don't see the smoke behind me.... and when the PDF is active, you can see check light (I read it in manual)
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by Barry View Post
    despite the manual, there is no light when the DPF is recycling (it should only come on when the DPF is full and cannot clean itself, but even that does not happen I think)... and there is no smoke visible neither...
    however only 3500 km and you had this often ?! do you do a lot of city traffic? next time it happens, don't stop but go on a motorway and drive until it stops... otherwise take it back to your dealer
  1. Carb cleaner while engine running
    By AFA82 in forum General Motoring Chat
    Last Post: 2nd February 2012, 15:06
  2. engine not running right
    By elite lee in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2010, 19:51
  3. Oil Change and now engine running cold?
    By Morzy in forum Engine & Drivetrain
    Last Post: 21st October 2010, 19:28
  4. Clean EGR while engine running
    By neverton in forum Diesel Engine related
    Last Post: 21st January 2010, 16:24
  5. Abnormal (?) Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 15th December 2008, 22:32
