Thread: Plasterer Required in Middlesbrough
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Default Plasterer Required in Middlesbrough
    Reet! I have finished plasterboarding the summer house and now it needs plastering. Is there anyone local that wants the job? I want it done cheap as its only going to be my office. Quick and dirty is good for me.
    Sunny Dartmoor
    Quote Originally Posted by Leviathan View Post
    Oh really Darren,does your missus know..........
    Quote Originally Posted by glenboy View Post
    Teeeheeeeheeeee Blush, yeah...her an I are on the same wave length
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    I've sent you a pm mate
    Quote Originally Posted by sparky71a View Post
    Cheers, will give him call ad see what he can do. Appreciate the effort matey.
    Nicking Ya Dinner.
    Why not have a go yourself, it's quite easy on plasterboard, bag of plaster 5.50, trowel 6.00 just need to follow a couple of rules
    1 - Tape the joints with mesh tape
    2 - PVA watered down 4-1 the whole lot
    3 - PVA again but this time put the plaster on it when the PVA is tacky
    4 - Push the plaster in an upward motion from the floor upwards on to the walls with your knuckles facing the roof, this helps lay it evenly
    5 - Flatten it out with bit of long straight wood
    6 - Smooth it out once levelled
    7 - Let it go semi hard and then apply some water to it and trowel out
    8 - Repeat this 2-3 times until you are happy with the surface
    9 - Finally push the plaster down hard, this helps get the glass effect.
    Thanks VV, I am tempted to try but not sure how it would turn out. If I dont find a cheap plasterer then I might give it a shot.
    Regular Member oil-burner's Avatar
    Jan 2008
    newcastle upon tyne
    couple of tips. if your plastering onto plasterboard you dont pva. dont use wood to level as it will "tear" the finish, leaving it almost imposible to finish. apply the plaster in two thin coats rather than one thick, one coat directly ontop of the other while still wet. if you do get too good a finish on the plaster when you come to paint it you will find it wont stick, and it will need a quick rub down with sandpaper to key.good luck
  1. Anyone near middlesbrough (Cleveland)
    By bigmac in forum General Chat
    Last Post: 28th August 2011, 11:12
  2. red vxr vectra Middlesbrough
    By willoftoon in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 4th June 2010, 20:38
  3. plasterer required.
    By VEC-MAN in forum General Chat
    Last Post: 13th December 2008, 23:48
  4. Wanted Plasterer local to Northampton...
    By merikiito in forum General Chat
    Last Post: 29th February 2008, 00:45
  5. Middlesbrough Mechanics
    By DarrenLee in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2007, 21:06
