Hi all just wanna know who uses iridium plugs? Are they worth the money & do you think the car run's any better with them? Not sure wether to get them for my car or not, due for srvice soon. Cheer's guy's
They handle a direct spark,and that fact should speak for itself,they will definately help as part of a set up.
What i can't remember is the part number because i need some replacements for my 2.2 sri petrol 56 plate....Anyone one here have an idea?
Got some IK16's on order for my 1.8VVti. Should make a bit of a differece. Will report back once they arrive (if they ever that is)
the only way how a spark plug will make a diffference to performance is if you have a current problem with your plugs
Deffo go for the Iridium plugs matey i use them in my V6 and they have smoothed it out nicely i also only used to use them in some BIG power fords that i used to own !!!!!
I have used many different types of spark plugs during my (to many) years of motoring and I have found that any top quality plug, correctly gaped (if required) will give you the identical result unless you have a very, very highly tuned engine in which case a very slight improvment could be felt, but on any 'normal' engine the cost could outweight any improvment aquired. For a rugged reliable plug at a cost that will not empty the wallet try the Bosch unit. I have used them for a while with no problem myself. I know that you will comment on this, please do as the sharing of information is what it is all about. Drive safely.
