Thread: iridium plugs question
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    Default iridium plugs question
    Hi all just wanna know who uses iridium plugs? Are they worth the money & do you think the car run's any better with them? Not sure wether to get them for my car or not, due for srvice soon. Cheer's guy's
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    They handle a direct spark,and that fact should speak for itself,they will definately help as part of a set up.
    What i can't remember is the part number because i need some replacements for my 2.2 sri petrol 56 plate....Anyone one here have an idea?
    Aberdeen
    Got some IK16's on order for my 1.8VVti. Should make a bit of a differece. Will report back once they arrive (if they ever that is)
    Apr 2008
    gosport
    the only way how a spark plug will make a diffference to performance is if you have a current problem with your plugs
    Deffo go for the Iridium plugs matey i use them in my V6 and they have smoothed it out nicely i also only used to use them in some BIG power fords that i used to own !!!!!
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    I have used many different types of spark plugs during my (to many) years of motoring and I have found that any top quality plug, correctly gaped (if required) will give you the identical result unless you have a very, very highly tuned engine in which case a very slight improvment could be felt, but on any 'normal' engine the cost could outweight any improvment aquired. For a rugged reliable plug at a cost that will not empty the wallet try the Bosch unit. I have used them for a while with no problem myself. I know that you will comment on this, please do as the sharing of information is what it is all about. Drive safely.
  1. ngk iridium plugs.
    By vectra gsi 3.2 in forum Northern Ireland (RO - Vacant)
    Last Post: 13th August 2012, 21:20
  2. iridium plugs for 1.8?
    By jimmyred in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 10:33
  3. iridium plugs question
    By Madgunner in forum Petrol Engine related
    Last Post: 5th January 2011, 15:06
  4. Iridium Plugs
    Last Post: 4th January 2009, 22:24
  5. iridium plugs
    By johnturbo in forum Petrol Engine related
    Last Post: 12th August 2008, 13:51
