Results 1 to 3 of 3
Thread: Rattle!!
    Apr 2008
    Mansfield
    Default Rattle!!
    Hi all.
    My first post, so hope you can help.
    First issue. My Vectra has developed an annoying rattle coming from the bulkhead area forward. It sounds very metallic and almost as if a "ping pong" ball is being tapped against the exhaust. It's clearly a very loose part as even when stationary and it's windy, it rattles. My first thought was the heatshield around the exhaust, but after getting underneath to have a look, it appears to be fine.
    Secondly, there is break squeal heard after the brakes have been released and I am accelerating away. This disappears after a short acceleration but returns once again when the brake pedal is subsequently released once again after braking. Any thoughts would be welcome.
    Sunny Dartmoor
    Could be the disc protection shield,it sometime's get knocked when changing disc's or a stone hitting it,check them out and let us know how you get on.......
    BTW :welcome to Vectra-c.com.........
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Tinny rattle !
    Quote Originally Posted by nautilas View Post
    Hi all.
    I had a very similar tinny rattle from the same area, after a lot of poking about, i found that the flexible gauze part of the exhaust ( between the down pipe and the middle section ) rattled and buzzed at various rpm's, i got rid of it by putting a jubilee clip around it !
  1. DMF rattle
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2013, 13:31
  2. 2.2 with a rattle
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:17
  3. Bad rattle!
    By heheshamon in forum Bodywork & Interior
    Last Post: 16th April 2010, 20:37
  4. A rattle at 70
    By Jezza181 in forum Engine & Drivetrain
    Last Post: 25th March 2009, 08:02
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
