Results 1 to 10 of 13
Thread: Dash top speaker
    Regular Member Diesel Dude's Avatar
    Norfolk
    Default Dash top speaker
    On my facelift CDTI under the centre vent in the dash top (between demist vents) there is a speaker with yellow and white wires going to it does anybody know where the wires go to.The car does not have a factory fit phone kit and has a cd70 fitted.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    You sure its a speaker i know some vecs have the climate control sensor thing there for sun sensor????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    To the back of the CD70 as it the centre speaker for the stereo
    Norfolk
    I thought it was a centre speaker for the radio but the wire colours dont match up with any on the back of the stereo and there is no sound from the speaker with the stereo on ,I had also been told its the speaker for the factory fitted phone kit.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The wires join the front door loom before it goes into the stereo, thats why there different. Although this is true on my half canbus im sure there was a thread that mentioned that it might be different on newer HU's.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    My wires are the same and I have sound from it. Factory fitted phone comes out of all speakers or at least the front two. If you look at the pinouts on the CD70 label you will see CE- and CE+ which are for the centre speaker
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Half canbus centre speaker has four wires going to it. Two from each side. Speaker is 4 ohm + 4 ohm. Full canbus speaker is 4 ohm and two wires.
    Norfolk
    If it is the centre speaker for the audio system when should i have sound coming from it,as its conected into the front speaker it should be on all the time.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    As far as I aware then sound should always be coming from it unless u have settings wrong in the CD70. It is very difficult to hear its working as u need to get close to it.Maybe use your phones recording program and hold it next to it
    Norfolk
    Thanks for your help I've just found this diagram for the cd70,I'll check it out tomorrow, does anyone know where the wires from the aux plug with the tel + in and tel - in go to or does anyone know what the other pins do.
  1. Dash speaker
    Last Post: 24th June 2012, 19:51
  2. Dash speaker
    By lee1828 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 20:24
  3. Centre dash speaker?
    By j6onn in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 00:10
  4. Speaker in the dash?!
    By Lightboy in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2009, 18:59
  5. dash top speaker
    By 06 vectra in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2009, 22:11
