Results 1 to 10 of 15
Thread: Just fitted these...
    Aberdeen
    Default Just fitted these...
    Elctormagnetic parking senesors. With my track record of 'fixing' things on the car I, it would be best if is stayed away from the drill, hence why I purchased these;
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=012
    Really easy to fit, you get a long silver foil like sensor that sticks behind the bumber, enough to go from one wheel arch to the other. I then put the control blok in the spare wheel well, and pushed the connector wire through the number plate rubber gormet. Connect to the reverse ligth and bob's your uncle.
    Seem to work good enough and very easy to fit. Plus no chance of making an @rse of the rear bumber drilling holles.
    Now does anybody know how to connect them to the parking switch on the dash?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    If it only works when the reversing light is on do you need it connected to the switch?
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Blimey thats cheap was looking at a similar system a few months ago and cheapest was £80
    Sunny Dartmoor
    You need the loom,and control box,iirc,bst bet would be to connect it to the white/black striped wire,that is the reverse wire.........
    Nr Cardiff
    That's handy, just bought one myself.
    Regular Member Peabrain's Avatar
    Apr 2008
    Purmerend (Holland)
    was just looking for parking sensors on Ebay but was not to keen on drilling the holes. This looks like a nice alternative. Thanks for the tip and the fitting instructions
    Regular Member Matty H's Avatar
    Bristol
    Quote Originally Posted by TheWildHaggis View Post
    Anyone know if these are quick and easy to install for someone with absolutely no knowledge of auto electrics whatsoever? Can someone do a how 2?
    Regular Member Draggon's Avatar
    Gloucestershire
    I like that ...was looking at the reversing cameras and screens ...but that is much neater
    Question is...does it work well...how much have you tested it?
    Good find btw
    Aberdeen
    Seem to work allright, tryed them out today in the local Asda carpark and seem to be fine.
    I can put together a how too for anbody interested on how to do install these, If i can do it then anybody can!
    As for the switch, I am thinking of getting some sensors for the front as well, so the swithc could be used to turn the front sensors on/off. I shall invesitage this a bit more.
    Home
    hi thewildhaggis, have you investigated the front switch idea further & also how sticky is the strip as when your motoring along & it's raining it must catch alot of water back there. How high up the bumper did you mount it, cheers. I am looking at purchasing one of these as they look far better than the sensor idea, etc.
  1. just fitted the k&n 57i .
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 22:49
  2. Hid fitted
    Last Post: 29th December 2010, 19:16
  3. anyone got or fitted??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 09:50
  4. Just Fitted.......
    By KeefyB in forum Petrol Engine related
    Last Post: 22nd January 2010, 21:38
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
